R50/53 r53 Exhaust recommendation
Old Mar 16, 2021 | 08:11 AM
idickers's Avatar
idickers
My daughter's 2002 r53 MCS has an exhaust that is more rust than metal, so I'm looking for recommendations to replace from the cat back. This is for a daily driver so it can't be obnoxiously loud, and she drives it in the winter so rust resistance is an issue.
Options seem to range from factory stainless steel ($$$) to aluminized steel from a number of distributors ($). Then I stumbled on a number of performance stainless steel options at ECSTuning that seem to be mid-priced between low-budget and factory. Has anyone tried the resonated cat-back systems from Milltek or Scorpion? Or are there better options for a stainless exhaust for a daily driver?
Old Mar 16, 2021 | 10:02 AM
Milltek is nice and on sale right now. Resonated if you dont want it to be super loud. Nice tone and sound. Scoprion is a good option, but not in stock here at ECS right now. I would go milltek because its on sale right now. Good luck in the search,
https://www.ecstuning.com/Mini-2005-...t/Performance/
Old Mar 16, 2021 | 11:00 AM
nd-photo.nl's Avatar
nd-photo.nl
There are a lot of options, I chose the Gravity Performance mostly due to the Carbon tips haha. They fit in nicely with the look I am going after with my R53. I swapped it with a JCW exhaust, which I experienced as too silent for the character of the car.
Good luck with your choice!
Old Mar 16, 2021 | 01:24 PM
bump32's Avatar
bump32
+1 for the Milltek resonated. Just installed one two months ago.
Post #216 for more of my thoughts on the Milltek.
https://www.northamericanmotoring.co...ml#post4571186
Old Mar 16, 2021 | 01:28 PM
idickers's Avatar
idickers
Thanks for the input! Does the Milltek exhaust use the stock rubber bushings on the hangers in the back?
Old Mar 16, 2021 | 01:43 PM
bump32's Avatar
bump32
Yes it does. BUT you will probably need new ones.....
use REALOEM.com
There are two #6. You can get the exhaust hangers (bolt up to the frame/sheet metal) from WAY, ECS or Pelican...
Also you may need to bend the rear hangers slightly. Mine was pressed right up against the rear bumper plastic and it need to come down.
Heat and a vice did the trick.
****One more thought for someone who knows more than me....Are the mid hangers the same as the rear hangers??? (number 6 and 14?) I only replaced the rear hangers #14, my mid hangers were fine.
Old Mar 16, 2021 | 01:49 PM
JAB 67's Avatar
JAB 67
Milltek gets my vote too, but don't waste your money on the resonator.
Old Mar 16, 2021 | 02:26 PM
idickers's Avatar
idickers
use REALOEM.com
Thanks. It looks like on my early car I use 4 of #13, and on 2004 and later cars they use 2 #13's and 2 #14's.
Old Mar 16, 2021 | 04:33 PM
NoBars's Avatar
NoBars
I just put a slightly used invidia on mine. I’m pleased with the reasonable tone.
The mid pipe and rear hangers are significantly different.
Old Mar 16, 2021 | 05:03 PM
OCR's Avatar
OCR
Agreed on the Milltek on my 05, JCW also.
Fit without problems, sounds good, not too loud at all. no highway drone. Actually fixed a mid-rpm hesitation, or better soft HP spot over the JCW, cat-back exhaust.
Mike
Old Mar 22, 2021 | 05:42 PM
Easy-E's Avatar
Easy-E
I did the milltek, with the resonator, sounds nice no droning and no loud crackling. Everyone with an automatic, stock ,non performance car around me has the non resonated exhaust, not for me, My02- E
Old Mar 22, 2021 | 05:44 PM
Easy-E's Avatar
Easy-E
And+1 for getting new hangers when doing the exhaust... don’t ask how I found out old ones were brittle and broke...🤦🏻‍♂️
Old Mar 22, 2021 | 06:06 PM
idickers's Avatar
idickers
Thanks, I ended up ordering the resonated Milltek. Plus all the rubber hangers, for exactly the reason you implied.
Old Mar 31, 2021 | 09:33 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Glad you went with the Milltek it is the best choice, and even better you got it during the sale. It's pretty much the only one we recommend in our shop anymore.
https://www.waymotorworks.com/millte...w-exhaust.html
Old Mar 31, 2021 | 10:02 PM
OCR's Avatar
OCR
Another vote for the Miltech.
Fits well, easy to install, and sounds fairly good, if a little on the quiet side, and made of stainless steel.
Mike
Old Apr 2, 2021 | 10:55 AM
nd-photo.nl
Made a new video not too long ago for the ones seeking for something else
wikdr53
Aug 17, 2020 01:34 PM
06minirube
Aug 3, 2020 05:14 AM
Joel614
Sep 9, 2019 10:23 AM
Bigmini828
May 27, 2016 09:23 PM
