Interior/Exterior Alta Short Shifter Adapter for using Whalen knob
Alta Short Shifter Adapter for using Whalen ****
Hi all,
Understand that Alta have produced the adapter for their previous short shifter to enable their short shifter to use the Whalen or stock ****,will be ordering one shortly, I will like to check whether any Mini owners here have actually bought and fitted this adapter recently and does this adapter result in any shifting height difference when comparing with the short shifter without the adapter installed?
Thank you in advance to anyone’s input.
Happy motoring…..
Happy motoring…..
I talked with Alta in November and they had not released the adapter yet. They said sometime in the first part of the year. I decided to get Doug to make my Whalen **** for the Alta because the adapter will raise the **** between a 1/2'' and a whole inch. Hope that helps.
so I gave my original one away to a friend.Earl
Hi all,
Appreciate all you guys inputs...
Thank you brian, understand that you have gotten some Alta short shiter's adapter, can you shoot some photo if possible to show how does the adapter looks light, does it replace the whole adjustable top stick shift part of the original alta short shifter?
Thank you.
Cheers
Thank you.
Cheers
Originally Posted by ilovepanerai
Hi all,
Thank you.
Cheers
Thank you.
Cheers
patsum
26
May 29, 2021 06:29 PM
wildwestrider
Dec 27, 2015 08:20 PM
67morris
Dec 1, 2015 12:53 PM
SneedSpeed
Sep 2, 2015 05:34 AM
