Interior/Exterior Alta Short Shifter Adapter for using Whalen knob
Old Jan 3, 2005 | 06:54 AM
ilovepanerai's Avatar
ilovepanerai
Alta Short Shifter Adapter for using Whalen ****
Hi all,
Understand that Alta have produced the adapter for their previous short shifter to enable their short shifter to use the Whalen or stock ****,will be ordering one shortly, I will like to check whether any Mini owners here have actually bought and fitted this adapter recently and does this adapter result in any shifting height difference when comparing with the short shifter without the adapter installed?
Thank you in advance to anyone’s input.
Happy motoring…..
Old Jan 3, 2005 | 09:59 AM
MINI Monkey's Avatar
MINI Monkey
I talked with Alta in November and they had not released the adapter yet. They said sometime in the first part of the year. I decided to get Doug to make my Whalen **** for the Alta because the adapter will raise the **** between a 1/2'' and a whole inch. Hope that helps.
Old Jan 3, 2005 | 10:15 AM
10851CS's Avatar
10851CS
I did the same and Doug made me one to fit with out an adapter. so I gave my original one away to a friend.
Earl
Old Jan 3, 2005 | 12:41 PM
Brian Spielman's Avatar
Brian Spielman
The difference between the two white lines is 3/4". Hope that helps.
The whalen adapter used for this demonstration is now on sale
Old Jan 3, 2005 | 10:01 PM
ilovepanerai
Hi all,
Appreciate all you guys inputs...
Thank you brian, understand that you have gotten some Alta short shiter's adapter, can you shoot some photo if possible to show how does the adapter looks light, does it replace the whole adjustable top stick shift part of the original alta short shifter?
Thank you.
Cheers
Old Jan 4, 2005 | 07:21 AM
Brian Spielman
Originally Posted by ilovepanerai
Hi all,
Thank you.
Cheers
These are the only pics I have right now. The adapter screws in a little past the last thread of the shift rod.
patsum
26
May 29, 2021 06:29 PM
rtk90
Aug 29, 2019 09:08 AM
wildwestrider
Dec 27, 2015 08:20 PM
67morris
Dec 1, 2015 12:53 PM
SneedSpeed
Sep 2, 2015 05:34 AM
