R50/53 Coolant leak
Old Feb 13, 2021 | 10:15 AM
KINGR2R's Avatar
KINGR2R
Coolant leak
Hi guys ,my R53 started to act funny . I took The inter cooler off an is full with coolant .Anyone else had this problem? What was the fix?
Thanks in advance .
Old Feb 14, 2021 | 05:46 AM
mrbean's Avatar
mrbean
That's a real head scratcher.
When you say it was acting funny can you be more specific?
Old Feb 14, 2021 | 05:57 AM
KINGR2R's Avatar
KINGR2R
[QUOTE=mrbean;4573972]That's a real head scratcher.
When you say it was acting funny can you be more specific?[/QUOTE
Random misfire and still driveable not as bad to trigger the check engine light .
I am suspecting water pump as I had some heating issues prior so I’m working on it now.
Working at -11 is no fun lol
Old Feb 14, 2021 | 09:13 AM
mrbean's Avatar
mrbean
Even though the CEL hasn't come on there could still be error codes. Give it a scan.
I don't think it's coming from the water pump. Even though it's connected to the SC, there's a sizeable air gap between the two - as well as an oil filled PTO.
I would also be curious if other areas of the intake have coolant in them (air filter box, the plastic tube between the TB and SC).
Old Feb 14, 2021 | 12:57 PM
KINGR2R's Avatar
KINGR2R
The intake ,air box , BPV are dry .When I opened the SC drain to drain the oil , surprise coolant was pouring out , let it drain out and added SC oil , changed the flange , pump , added oil in the front of the SC put everything back and drove for half n hour. In the fort 10 min the engine had hesitation but noticed a huge improvement toward the end of the ride.
Keeping fingers crossed that my issue is solved .
Old Feb 14, 2021 | 01:27 PM
KINGR2R's Avatar
KINGR2R
Old Feb 15, 2021 | 04:38 AM
nd-photo.nl's Avatar
nd-photo.nl
The water pump is on the other end of the SC. My best guess would the that side...
Old Feb 15, 2021 | 01:20 PM
kaneguy's Avatar
kaneguy
My 2 cents.... The waterpump is not directly integrated with the super charger but driven by external linkage so it coolant is not coming directly from the cooling system. But I suspect that there is a coolant leak that is being drawn into the intake. Since you stated that the BPV valve is dry then the only place down stream that would be able draw in any coolant would be Super Charger input flange that is just below the water pump. If the water pump or hose is leaking and dripping on to that flange and it is not completely sealed the high vacuum would draw in the coolant. Any vacuum leak at that flange would also cause performance degrade.
Old Feb 15, 2021 | 02:54 PM
KINGR2R's Avatar
KINGR2R
[QUOTE=kaneguy;4574140]My 2 cents.... The waterpump is not directly integrated with the super charger but driven by external linkage so it coolant is not coming directly from the cooling system. But I suspect that there is a coolant leak that is being drawn into the intake. Since you stated that the BPV valve is dry then the only place down stream that would be able draw in any coolant would be Super Charger input flange that is just below the water pump. If the water pump or hose is leaking and dripping on to that flange and it is not completely sealed the high vacuum would draw in the coolant. Any vacuum leak at that flange would also cause performance degrade.
Thanks for you input.Your 2cents worth like $200 !
Old Feb 15, 2021 | 05:18 PM
Apexlate's Avatar
Apexlate
Did you notice any coolant leaking under the car?
Jimmy Chiu
Jan 4, 2020 12:12 PM
jsweewong
Apr 18, 2016 08:37 AM
kapps
Dec 1, 2005 08:40 AM
Corbyzz
Jul 10, 2003 10:31 PM
