R50/53 Corroded Muffler Hanger Solution Request
Old Feb 8, 2021 | 09:26 AM
Buggy's Avatar
Buggy
05 S with 131,000 cared for miles by one owner. Went to replace a muffler hanger located in the rear on the passenger side. There are 2/ea, 8 mm ? (please confirm) studs coming through the boot that are attached to a 4" bracket, (see photos) The studs were rusted into nothing. This inside the boot bracket is spot welded into the boot but I was able to free it with no damage. Question; can anyone recommend a fix? I was going to repair the original boot bracket and fabricate new 8mm studs on it. Thought I would check here first if anyone had a personal solution they would like to enlighten me with.
Thanks in advance,
Buggy
underneath view of area showing 8mm studs and nuts
Inside the boot top view of bracket
Inside the boot angle with ruler
Old Feb 8, 2021 | 09:43 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Could you redrill the holes and feed a bolt and nut through? Could use a rubber washer on the nut to prevent moisture from coming up .
could always look into possibly the universal hangers and attach them in a different location so long as the exhaust is supported.
but I coulda swore the exhaust brackets can be unbolted and replaced
Old Feb 8, 2021 | 10:33 AM
jcolletteiii's Avatar
jcolletteiii
I'm in the same boat man. Broke both of the rear studs off getting my brackets off so I could drop the rear heat shield. My plan is to drill out all 4 studs and replace with stainless, epoxy them in and then re-rubberized undercoat around them top and bottom. As for the brackets themselves - those suckers are pricey. I found one side for $35 from the Atlanta BMW/Mini place, the other side is like 75 bucks (stock must be low)! If you find another solution, I am interested in hearing it!
Old Feb 8, 2021 | 08:26 PM
MiniManAdam
Community Builder
If it wasn't so dang cold out I colda tried getting some fir u guys from my local salvage yards..
Old Feb 13, 2021 | 05:35 AM
Buggy's Avatar
Buggy
Found the solution. Networked with a local car repair entrepreneur that sourced this part for me. With the two nuts it was $15.00.
Old Feb 13, 2021 | 06:15 PM
jcolletteiii
Thanks for the follow up and solution - one more Q for you... are the sold singly or by the pair? Thanks!
Old Feb 15, 2021 | 07:39 AM
Buggy's Avatar
Buggy
I was able to purchase just the single unit.
eaglebeagle
R60/R61 Stock Problems/Issues
Mar 28, 2018 04:41 PM
mattmed03
61
Feb 10, 2011 06:32 PM
htcmdv01
Classic Mini Talk
Aug 12, 2008 04:21 PM
scribbledpaper
MINI5280
15
May 26, 2008 07:51 PM
