I have a problem with the pulsar spark plugs
Old Feb 7, 2021 | 07:31 AM
fight4life's Avatar
fight4life
i have 02 mini cooper s with some mods recently add, it has msd ignition coil, bigger intercooler, i put the alta performance kit with 17% pulley, and yesterday put the pulstar plasma core spark plugs (be1h10) and went to a ride and when i push the pedal began to fail, so i put the ngk spark plugs and fixed but already spend $60.00 with the pulstar, does anyone know if they work or not?
Old Feb 8, 2021 | 01:37 PM
mrbean's Avatar
mrbean
Pure snake oil. Stick with NGK.
Old Feb 9, 2021 | 04:56 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The metal crush washer on anything but NGK are made of inferior composite metals thus even after torque to spec, they eventually blow out stripping the threads = you saved nothing.....Stick with NGK.
And never use anti-seize compound on the threads !
Old Feb 9, 2021 | 07:12 AM
fight4life's Avatar
fight4life
Ok thanks for your replies, just the last question what ngk plug do you guys recommended for the 17% pulley? Iv been searching and this 2 models came up :
NGK BKR7EQUP (4285)
ngk BKR6EQUP (3199)
could you recomend wich is correct?
Old Feb 9, 2021 | 03:28 PM
WolfUSAR's Avatar
WolfUSAR
I’ve never used anything but NGK plugs in any of my cars, when I did I ran into issues. My previous car was a ‘96 V6 accord and I never had a problem with the NGK plugs even though it burned a little oil. Car before that was a ‘92 Accord and ran NGKs in that too. Switched to them in the R50 as well.
rescay
Nov 4, 2012 02:54 PM
2004JBMINI
Jul 2, 2012 12:02 PM
Archanum
Jun 17, 2008 01:40 PM
