R55 Clearing P0128 Code after Head Gasket Repair
Old Feb 1, 2021 | 10:52 AM
Jim L Smith's Avatar
Jim L Smith
Hi all, thanks for this awesome resource. I'm trying to sort out a P0128 code on my 12 Clubman. CEL light came on a few months ago, along with fan running constantly and rough idle. It's now had 2 new thermostat housings, new water pump and, wound up at a good local import shop. They pressure tested it and came back with a bad head gasket. I went ahead and did the head gasket myself, got it back together and it's exactly the same. Same code, same rough idle. I just ordered a new engine coolant temp sensor, but I'm wondering if there's any other thoughts on this. Someone has recommended resetting the adaptations, but I don't have an OBD 2 scanner that can do that. Would love your thoughts on this, thanks.
Old Feb 1, 2021 | 11:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
According to https://bmwfault.codes/ its "Coolant temperature sensor, signal: Permanently stuck at low":
https://bmwfault.codes/XMLDiagView?d...cAOAAyADAANAA=
On the N18 engines there was a jumper harness for the coolant temp sensor. It is possible that the temp sensor is bad, but I might think that is a break in the harness of sensor connections.
J_Stark
R55 :: Clubman Talk (2008+)
15
Jan 7, 2021 01:16 PM
renchjeep
Jul 23, 2020 08:35 AM
Teh_Burninator
Mar 5, 2016 02:06 PM
R56typeS
Sep 16, 2013 06:51 PM
kamikazy
Classic Mini Talk
Aug 4, 2007 09:37 AM
