R50/53 Do I need a new flywheel?
Old Jan 30, 2021 | 10:27 AM
ladsjohn's Avatar
ladsjohn
I posted on here a few weeks back about my experience with my Valeo clutch. I installed it 2 years and 10K miles ago replacing the stock DMF setup. Recently it began slipping again. I put it down to my driving style after recently installing a sprint booster. I don’t believe there were any issues with the install or with the product.
I bought a replacement friction disc kit and went to install it this week.
I’m unsure if I need to do the flywheel too
. Would appreciate any advice here based on the attached photos.
Old Jan 30, 2021 | 10:32 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Get it resurfaced..
Old Jan 30, 2021 | 10:44 AM
ladsjohn's Avatar
ladsjohn
Originally Posted by shrevemini
Get it resurfaced..
good call. I didn’t even think of that. Are these bolts TTY or reusable?
Old Jan 30, 2021 | 10:45 AM
FakeName's Avatar
FakeName
Maybe it can be resurfaced- but it's pretty bad. I've never once read of a MINI owner resurfacing a flywheel. That will need a LOT of material removed to get to undamaged material, which will change the dimensions- the relationship between the pressure plate and the disk.
Yes, I think replace.
Old Feb 3, 2021 | 11:08 AM
ladsjohn's Avatar
ladsjohn
My local transmission shop figured it needed a '2 stage' resurface which was going to cost $125.
I decided upon a new one ($200) instead. Thanks for the advice!
Old Feb 4, 2021 | 07:40 AM
AngryScotsman's Avatar
AngryScotsman
Also, I would replace the flywheel and pressure plate bolts while you're in there.
Or get ARP hardware.
I've seen snapped flywheel bolts because a guy reused them a few too many times. Imagine trying to drill out a hardened bolt out of a crank. Ugh.
Old Feb 4, 2021 | 10:28 AM
ladsjohn's Avatar
ladsjohn
Ta mate. Ya - the new kit comes with new flywheel bolts.
CakeEater
Sep 3, 2020 09:17 AM
booyah93
11
Mar 16, 2020 08:22 AM
ioannes79
Jan 17, 2019 07:57 AM
sterlingarcher
Jul 3, 2018 12:18 PM
xsmini
Aug 10, 2016 12:20 PM
