Suspension Information/parts request
Old Jan 2, 2005 | 03:08 AM
minniedryver's Avatar
minniedryver
I am gathering parts for a suspension upgrade to my '04 Cooper. My plan is to have two complete sets of struts/springs, so that I may drop the car for Spring, Summer and Fall, and then raise it back to stock for the Winter...
I currently have a set of stock S struts, spring 'hats', and mania drop springs. What I need info on, are the nuts, washers etc. that will be required at the top of each assembly. Does anyone have a picture of a disassembled strut/ spring assembly, or is there an exploded diagram anywhere online?
I don't want to wait until I pull the struts out to see what is required and then go hunting for nuts and washers!
TIA,
Old Jan 2, 2005 | 07:42 AM
jlm's Avatar
jlm
the hardest part of front strut changing is compressing the spring and removing the upper bearing assembly. Why don't you get another set of upper bearing assemblies and leave them attached to the struts. then swapping the struts would be much simpler.
Old Jan 2, 2005 | 07:03 PM
MiniPilo's Avatar
MiniPilo
Send me an e-mail, and I'll send you an assembly page.
dan@piloracing.com
Old Jan 3, 2005 | 01:51 AM
minniedryver
Ah, 'strut bearings'...I had a brainfart and used 'hats' in my original post! I have the bearings for all 4, I just need the nuts and any associated washers to hold it all together...
Dan, email on the way...thanks!
Old Jan 3, 2005 | 07:04 AM
CoryB
You could install an airbag suspension and raise and lower it at will.
NorthWestEuro
Oct 22, 2016 07:57 AM
NorthWestEuro
Oct 20, 2016 06:41 AM
j_parker
Nov 8, 2015 04:54 PM
rt808
Sep 29, 2015 12:30 AM
