R50/53 Rt Front Vibration
Old Jan 20, 2021 | 04:13 PM
Adiru55's Avatar
Adiru55
Rt Front Vibration
I recently purchased an 06 R50 with automatic transmission, the CVT was replaced just prior to purchase. Recently it has developed a vibration in the right front that vibrates everything loose in the cabin. I have replaced the rt. front bearing assy(it was whining), replaced the serpentine belt tensioner, and had the tires balanced and rotated. I looked at the harmonic balancer and it appears to ok. What am I missing?? I cannot stand to drive the vehicle as it is. Any advice would be greatly appreciated!
Old Jan 21, 2021 | 09:31 PM
deepgrey's Avatar
deepgrey
Does the vibration shake the steering wheel?
Old Jan 22, 2021 | 01:45 AM
Adiru55's Avatar
Adiru55
No, its more like engine or drive axle? I read an earlier post yesterday concerning the same issue and everyone said harmonic balancer. Apparently they degrade on the engine side, who knew?
Old Jan 22, 2021 | 04:25 PM
Zsm's Avatar
Zsm
If the vibration is while at speed, I'd be suspicious of the CV axle.
Old Apr 7, 2021 | 07:57 AM
Adiru55's Avatar
Adiru55
Update, So turns out it was the right front hydraulic damper. Once I had an idea of what a bad one looked like thanks to YouTube, A new damper from Pelican Parts did the job. I can't believe the amount of noise that was transferred into the cabin from this bad mount.
CARdiac
Dec 30, 2009 09:30 AM
wsj3200
May 29, 2007 05:50 PM
foko
Tires, Wheels, & Brakes
Nov 5, 2006 07:20 PM
nicolemarin
Jun 23, 2005 10:49 AM
dconte007
Apr 21, 2005 06:37 AM
