timing chain
Old Jan 10, 2021 | 11:52 AM
gbrides's Avatar
gbrides
timing chain
Can't find this in previous posts. Have a 2003 s with 140,000 miles on it and am starting to think about repairs to anticipate. Number one is how long should I get out of the original timing chain and is there any way to know it's condition without tearing it down? If needed, what is a reasonable cost for replacement by a shop? George
Old Jan 10, 2021 | 12:38 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I'm doing my chain next weekend. There is a couple ways to tell if it is time.
1. Is if you hear a distinct taping sound coming from the engine.
2. While engine is running get close to timming chain side an listen to it.
3. If you remove cover. Then pull on the chain to see if there is any slack in chain.
I'm doing the chain by myself. I have all the tools needed to do it. Not very hard to do. But like I said you need the correct tools.
While I'm in there. I'm going to inspect the camshaft for ware or damage. Then you check the lifter tap for an damage or ware.
Since you have an S model. Especially withe the miles. Now is a good time to replace the pulley on the crank. They are known to fail.
Going to change mine. Even though it is a none S model.
Old Jan 10, 2021 | 04:39 PM
gbrides's Avatar
gbrides
thanks...
Old Jan 10, 2021 | 08:13 PM
ghostwrench's Avatar
ghostwrench
At that mileage, I'd be more concerned about the condition of the PTO gears in the supercharger than I would be with the timing chain. If you haven't done a supercharger service yet, I recommend you prioritize that lest you learn the lesson I just learned about those gears.
Old Feb 25, 2021 | 12:18 PM
DiscoDave's Avatar
DiscoDave
Oil was gone? I'm servicing my supercharger soon but have yet to research exactly what that means besides changing the oil...
Old Feb 25, 2021 | 12:49 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Some superchargers tend to leak out or basically use up the oil in the pto side. When this happens it can cause catastrophic damage to the gears in the pto housing the gears that drive waterpump. If of course your mini is supercharged.
Old Feb 25, 2021 | 07:19 PM
ghostwrench
Yes, oil was gone. Nothing but dirty, metal dust in the PTO housing with the worn gear teeth.
Old Feb 26, 2021 | 05:11 AM
DiscoDave's Avatar
DiscoDave
YIKES! Point Taken.
ala1129
Aug 5, 2020 11:14 PM
Jul 19, 2015 10:15 AM
BushOner
Jul 16, 2014 02:49 PM
mcs1984
Jul 5, 2012 10:25 AM
