R50/53 DSC light on at high boost levels?
Old Dec 28, 2020 | 04:30 PM
alconk's Avatar
alconk
Is it normal for the DSC light to come on at high boost levels? Anything over 18# it triggers the light and stays on until I shut the car off. I seem to remember but not too well that it was normal but not sure.
Old Dec 28, 2020 | 05:31 PM
Serafin's Avatar
Serafin
off topic, but how are you getting 18 psi?
Old Dec 28, 2020 | 05:39 PM
alconk's Avatar
alconk
I keep getting the same question, 16% under drive pulley and a 2% crank pulley. Boost gauge
can only achieve this in the winter with colder denser air, summer time can only get 18 and on really hot and humid days 16.
Old Dec 28, 2020 | 06:08 PM
Serafin's Avatar
Serafin
i have 17% plus 2% overdrive.. i get 14 max , scorpion headers de cat .. borla exhaust , catcam bytetronik tune as well..
Old Dec 28, 2020 | 06:10 PM
alconk's Avatar
alconk
I don’t know what to tell you? I have a Miltek full exhaust 380cc injectors ported intake and a custom tune. Every car will be different.
Old Dec 28, 2020 | 07:54 PM
Serafin's Avatar
Serafin
Yeah. I think it’s the cam. Also got 550 injectors.
hows your IAT? What intercooler you have?
Old Dec 28, 2020 | 09:22 PM
alconk's Avatar
alconk
don’t know and stock, did have a Airtek but didn’t perform as good as stock
Old Dec 28, 2020 | 11:34 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Off topic but on my setup with just 17% pulley but larger ic, tpr2 head , ns1 cam , ported manifold , ported headers and no cat and a dt bpv.. with this cold air i can get 17.5 psi even.
Old Dec 28, 2020 | 11:36 PM
MiniManAdam
Community Builder
I have read that it does trip some light after a certain boost level but I cannot confirm what light or code ect it does throw . But I do know they do. Lol I was kinda worried seeing 17.5 but that was once as it was like 11 degrees out and crisp. I doubt ille ever have it out in that cold again . Just luck we've had no salt on the roads ( up until yesterday atleast ) and decent weather so far..
alconk's Avatar
alconk
I’m not here to compare it is what it is just trying to figure out what the issue is.
Old Dec 28, 2020 | 11:38 PM
MiniManAdam
Community Builder
nor am I, just stating that fir the other guy asking about boost levels . Every cars different even down to how they've aged so its like comparing apples to oranges .
alconk's Avatar
alconk
yes I just recently confirmed that there is a overboost that will trigger the DSC light anything over 18#. Having my tuner rewrite my tune to turn it off
Old Dec 29, 2020 | 08:38 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I would love to know if that is a real psi reading, your mods should not make that much boost, no where near that much boost unless something is wrong like a plugged cat or muffler
Old Dec 29, 2020 | 09:26 AM
alconk's Avatar
alconk
Here is a video from today
File Type: mov
Old Dec 29, 2020 | 09:57 AM
MrBlah's Avatar
MrBlah
If that were my car I would pull the timing cover off and check the timing marks for the cam that will also cause a high boost air and will really limit power. If the cam timing is right I would then pull off the header and stick a camera down at to see if the cat is plugged
Old Dec 29, 2020 | 09:59 AM
alconk's Avatar
alconk
There is no cat and only hits this boost in the winter.
Summer time I only get 16-17 and if it’s real humid 14
Old Dec 29, 2020 | 10:03 AM
alconk's Avatar
alconk
Can you explain further about the timing marks? It runs very strong right now.
Old Dec 29, 2020 | 10:11 AM
MrBlah's Avatar
MrBlah
doesn't matter if it's winter that's still more boost than your mods should possibly make.
If you pull the crank damper and the timing cover off there are marks on the crankshaft and on the cam gear you have to spin the car a hell of a lot of times eventually they line up with colored chain links You're probably off one tooth
I had the same problem when I installed my PH3 somehow I ended up one tooth off boost was crazy high, The cylinder compression psi was too low, didn't make as much power as it should have
Old Dec 29, 2020 | 10:21 AM
alconk's Avatar
alconk
ive never had the internals apart and did replace the damper with a ATI but that would matter since there’s no key way. Are you saying chain could have jumped a tooth?
Old Dec 29, 2020 | 11:17 AM
MrBlah's Avatar
MrBlah
Has has your car always been this way?
I've had the pleasure of dealing with a chain that was off one tooth during a cam install and I had the pleasure of a chain jumping when the car was idling at like 100 RPM and it was about to stall it made a pop backfire sound and it jumped a tooth
Old Dec 29, 2020 | 02:11 PM
alconk's Avatar
alconk
I’ve had it for two years and when it gets cold out the boost goes up a couple pounds but like I say in the summer if it’s a hot and humid day all I can get is 16#. So to your question yes it’s always been this way after I installed the pulley and damper which was right after I bought it.
Old Dec 29, 2020 | 04:13 PM
MrBlah's Avatar
MrBlah
a little boost increase is normal, 18psi hitting ecu limp is not, definitely not with a M45 and a cam unless you had like a 25 % supercharger lol
Old Dec 29, 2020 | 04:24 PM
Serafin's Avatar
Serafin
That made sense though. Prolly when the cam installed it jumped a tooth.
had to buy the cam tool and made sure i was careful when i did mine. Heard stories about this. Good luck man. Hope you can find the culprit.
Old Dec 29, 2020 | 10:21 PM
alconk's Avatar
alconk
cam is stock, thanks
astroBlackMetallic_Mini
41
Apr 1, 2015 06:07 PM
GreenHornet03
Nov 19, 2014 04:22 PM
200-OK
Dec 16, 2006 12:14 PM
CustomAV
Jan 27, 2005 10:32 AM
