Strut mount squeak
Old Nov 28, 2020 | 04:08 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Strut mount squeak
I just replaced my front struts. I replaced the upper mounts with new KYB mounts. Now my right strut my squeaking when u turn. Any thoughts?
Old Nov 29, 2020 | 05:30 AM
Eurothrasher's Avatar
Eurothrasher
When replacing struts I highly recommend replacing the additional absobers and lower spring pad along with usual hardware.
It could be RF spring rubbing against older worn parts of the assembly if still being used.
Old Nov 29, 2020 | 05:43 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
This happened to me too when I changed my struts for some Bilstein B6 --- it creaked like an old wooden ship on low speed turns.
I had noticed that my upper spring pads were quite worn, even slightly frayed on the edges, but I went ahead an re-used them because I had neglected to foresee the need to replenish them so didn't order. I was pressed for time and decided not to wait --- it was a mistake because I had to go back and do the job again just to add those dumb little pads.
#8 on this chart:
Note that the part is 3mm which is BMW's "sport" version which all the R50/R52/R53 series use I think?
Pretty thin really, and likely with high mileage age & wear gets compressed even thinner I'd imagine.
BMW has a "regular" version that is quite a bit thicker at 10mm (part# 31331135589) but use of it on a MINI would raise ride height by 7mm.
boater454
Apr 21, 2021 08:29 AM
Nicefeet
Suspension
Sep 18, 2014 05:24 PM
Wildman-1
Suspension
Jan 12, 2014 10:46 AM
turbodogz
Suspension
Aug 17, 2009 05:48 PM
davavd
Oct 4, 2007 03:33 AM
