Will 16x7.5 ET25 fit a stock R56?
Old Nov 20, 2020 | 03:29 PM
minitis's Avatar
minitis
Hi all
I just came across a really nice set of wheels: 16x7.5 ET25. Tyres are 195/40.
Will these fit a stock base model R56?
Thanks a lot.
Old Nov 21, 2020 | 03:54 AM
minitis's Avatar
minitis
So many views, so few replies
I know ET 25 is right at the edge - but is it out ot the question?
Old Nov 21, 2020 | 04:15 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
https://www.wheel-size.com/calc/?whe...cl=15mm&sr=0mm
I don’t think the wheel offset will be your problem. A 195/40-16 tire is nearly 2 inches smaller in diameter than stock size! You’ll want to go with a 195/55, or a 195/50-16 at the smallest.
Old Nov 21, 2020 | 08:54 AM
minitis's Avatar
minitis
Got it, thanks, I didn't have the diameter/speedometer in mind!
So if I went with a tire with higher diameter, say 195/55, I shouldnt have problem with clearance or rubbing?
Old Nov 21, 2020 | 11:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Are you still on stock suspension? Might look a little odd with wheel poke like that. Other than that, you shouldn't have any rubbing.
Old Nov 23, 2020 | 08:36 AM
minitis's Avatar
minitis
Yeah, everything is stock. But I will look for another set. Shame.
Old Nov 27, 2020 | 02:32 PM
krawzdogg's Avatar
krawzdogg
As far as the offset, you should be fine as long as you have adjustable rear control arms and front camber plates (or just slot the top mount holes). You’ll need to run slightly more camber (I’m running 2 degrees). I have 18x8 et32 215/40 which is almost identical in offset to a 16x7.5 et25. A 195 tire is pretty stretched on a 7.5. You would be better off with a 205. You will need to lower it from stock suspension for it to look right.
Xjsf28
Feb 11, 2019 11:11 PM
Andrew_C
Tires, Wheels, & Brakes
Apr 11, 2013 01:12 AM
MarinePMI
Nov 16, 2012 10:56 AM
vettestripes
Jun 6, 2011 02:24 PM
rexracerx9
Jun 10, 2010 09:38 AM
