R50/53 Name this sensor........
Old Nov 2, 2020 | 08:50 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Figure i might as well replace this sensor before I put everything back together for a 100th time to find i gotta take it apart to replace something simple.
Name of it please !
Old Nov 2, 2020 | 09:14 PM
jk6672's Avatar
jk6672
It looks like the map sensor.
https://www.waymotorworks.com/map-se...-cooper-s.html
Old Nov 2, 2020 | 09:38 PM
MiniManAdam
Community Builder
No. This is attached to the block...underneath the waterpump
crank position sensor ????
EDIT: Finally found it after that crossed my mind, yes it is a crank sensor and that is now ordered also to be replaced with my knock sensor..
Old Nov 2, 2020 | 10:00 PM
Zsm's Avatar
Zsm
The o-ring fails far more often than the sensor. I’ve gone through 2 in the last 30K. Well, anytime the car is that far apart I change the o-ring prophylactically.
Old Nov 2, 2020 | 10:20 PM
MiniManAdam
Community Builder
The one attached around the sensor ???
hope my car is FINALLY running correctly after this head n cam swap, chasing down these kinks is annoying. I wanna just wail on her and try on my buddies Hoosiers
Old Nov 3, 2020 | 05:48 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes that is the crank position sensor
https://www.waymotorworks.com/cranks...0-r52-r53.html
Old Nov 3, 2020 | 10:06 AM
nd-photo.nl's Avatar
nd-photo.nl
Yep, crank position sensor. Swap out the ring if you have never done that, as they will leak oil. You need to remove the sensor by removing the 1 nut and wiggling it out.
seamusnh
May 12, 2019 07:30 AM
rosahan
May 22, 2015 03:22 PM
auscoops
Dec 4, 2008 04:12 AM
cwoodwar
Jun 11, 2008 07:14 PM
