Suspension Replacement Swift springs for Cross JIC
Old Oct 27, 2020 | 05:52 PM
Bhozar's Avatar
Bhozar
I was speaking to Jan about getting some replacement springs for my Cross JIC setup I bought from him many moons ago, but he's not replying. Guessing either something has happened to him or it's not worth bothering with just supplying the springs to the UK.
I know the original springs were 400 lb front, 337lb rear, but that's all the info I have. I've found a supplier in the UK, but I'm short of the details I need to make a purchase. Does anyone know what springs are required for the Cross JIC setup for a road R53? Think I am slightly more nose heavy as I have a 1.8T VW engine rather than the 1.6, but the Cross JIC was always fine.
Needs -
Spring length:
ID:
Rate (F/R):
Found them all listed here: https://www.driftworks.com/suspensio...ilover-springs
Would be most grateful if anyone has switched their springs to Swift from the stock ones, or knows what Jan usually provides?
Thanks.
Old Oct 28, 2020 | 03:51 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
JIC went out of business, didn’t they? Looking at older pictures of those Coilovers, they look like regular 60mm springs. If you have the coilovers already, can’t you just pull out the springs and measure them up?
Old Oct 28, 2020 | 04:04 AM
Bhozar's Avatar
Bhozar
Dunno what happened to JIC. Was guessing the length of the springs is probably a lot shorter now as the car has been sat on them for years, but yeah, can measure to see if they are 60mm.
Old Oct 28, 2020 | 04:30 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I would be surprised if the springs were shorter after so many years. I would measure the free length, and get new springs that are similar. You can adjust the ride height and preload from there to suit your needs.
Old Oct 28, 2020 | 04:45 AM
Bhozar's Avatar
Bhozar
Cheers. Just figured as the car weight settled on the springs they would loose a bit of the length after 10 years in service.
clutchless
Suspension
Feb 25, 2012 08:30 PM
rider2J
Southern California
May 19, 2010 10:06 PM
joltfreak
Classic Mini Talk
Mar 17, 2009 04:09 PM
