Now accepting pre-orders for the next generation gauge...
Old Dec 29, 2004 | 10:47 AM
Brian Spielman's Avatar
Brian Spielman
Euro Styles East is now accepting pre-orders for the next generation gauge…
...Autometer’s Nexus Line.
Euro Styles East Pre-Order Details:
All of Autometer's Nexus line will be discounted 25% off retail from now until UPS delivers our first shipment sometime mid-January. We've placed a large stocking order but the gauges will be first come first serve. Since we put our backorder in sometime ago, Euro Styles East will be one of the first vendors to have these gauges available. All of Autometer's Nexus gauges will not be dropshipped, but will be shipped directly from ESE the day our initial shipment arrives.
Here's the pricing after the 25% off discount:
Nexus Sensor Module and Remote - $199 (Retails for $265)
Exhaust Temperature - $229 (Retails for $305)
Oil Pressure - $249 (Retails for $332)
Water Temperature - $199 (Retails for $265)
Oil Temperature - $199 (Retails for $265)
Boost / Vacuum - $249 (Retails for $332)
Fuel Pressure - $249 (Retails for $332)
Nitrous Pressure - $249 (Retails for $332)
Give us a call at (412) 821-2800 to place your pre-order or purchase securely via the web at www.eurostyleseast.com
From Autometer...
Click the Image below to view the Nexus Demo:
The next generation in high tech, precision automotive instruments is here. Are you prepared for the revolution? Subtle dark lenses and dials combine with a new "lens forward" bright-anodized bezel design for a clean, modern and stealthy appearance. Twist the ignition key, and NEXUS flares to life. An intense Initialization sequence reveals "through the dial" LED illumination, diagnostic checks, pointer calibration, and zeroing. When NEXUS is operational, utilize the illuminated remote control to customize your experience:
Choose from several different illumination colors and five levels of dimming or activate the Dynamic Color Sequencing Light Display and watch NEXUS shift through the color spectrum on its own.
Program warning point for each of the seven gauges in the series and take advantage of the Full Dial "Red Alert" Warning System. NEXUS pioneers the use of full analog dial color change to alert drivers to critical conditions.
Record all gauge channels and RPM data for up to 35 seconds of playback with NEXUS internal memory.
Review continuously updated peak reading values for each gauge channel.
Or select the Demo Sequence and give life to your interior whether sweeping a show or hanging out at the local hot spot.
When you're ready to get serious, pick up a Secure Digital (SD) card for the NEXUS remote and add the N1.0 software to your computer to expand your options:
Record up to 11 minutes of data per Mb of space on the SD card and download to the N1.0 software on your PC for graphical data analysis and virtual dash playback.
Program, download, and upload new Initialization, Shutdown, and Demo sequences on www.autometer.com for a completely custom gauge experience (coming soon).
Compact 2 1/16" (52mm) diameter makes installation easy into custom dashes, pods, pillars for carbon fiber cups. Powered by robust 270 degree sweep precision motor movements, and utilizing rugged and highly sensitive electric sensors, NEXUS provides maximum accuracy and safety. Simple installation and gauge network additions are made possible via modular cable connections and N1.0 Network technology. Remote control and sensor module required for operation. SD card and N1.0 software available separately.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
