R55 2012 r55 Clubman body/suspension
Old Oct 19, 2020 | 08:19 PM
Peter Burg's Avatar
Peter Burg
Hello All! I am new to forums so please be gentle!! I have a 2012 Mini Cooper Clubman R55 base in pepper white that got into a fender bender. Long story short I am in need of a bumper cover (with all attachments fog lights etc.), passenger side fender, air bag for a 3 spoke steering wheel and entire passenger side suspension. I am having a hard time locating used clubman parts but regular mini parts are readily available. Are the parts the same? the bumper cover looks the same, suspension looks the same. Any thoughts?
Thank you
Peter
Old Oct 20, 2020 | 03:25 AM
Jason Cornelius's Avatar
Jason Cornelius
If I’m not mistaken, R55 and r56 are the same from the doors forward or to the b pillars.
Old Oct 20, 2020 | 09:42 AM
bugeye1031's Avatar
bugeye1031
Moderator
Jason is correct....these parts from an R56 will fit directly on your Clubman.
Also, you may do better by purchasing a "shell" (body without a running engine) and transferring the parts to your car. You can occasionally find someone selling a shell on CL or FB Marketplace....our race team has bought them for $500 to $1500....much cheaper than going to a recycler for the individual parts. If you're in the New England area or Philly areas I can put you in contact with suppliers. PM me if so.
Old Oct 21, 2020 | 05:56 AM
crazy4trains's Avatar
crazy4trains
Try RealOEM.com. You can search by VIN and cross reference part numbers. Powerful tool.
Old Oct 22, 2020 | 08:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For sure you can use the regular 2 door hatchback R56 parts as they will be the same. The only thing is for the rear spring you should reuse your clubman spring as it will likely be a different rate than the other.
Old Oct 27, 2020 | 02:08 AM
Peter Burg's Avatar
Peter Burg
Bumper, airbag question
Thank you all for replies, Wish I would have known about the compatibility with other models before I bought new a new bumper. I called multiple salvage yards and with shipping charges it wasn’t too much more to buy new from the dealer. The airbag went off, I bought a used one, do I need to replace anything else? clock spring, impact sensor? Do you need to “marry” the bag to the car?
mini-s-man
R55 :: Clubman Talk (2008+)
Jun 28, 2024 06:50 AM
JohnJohn
Jun 27, 2020 10:35 AM
Minimist
36
Dec 9, 2012 11:25 AM
chrisxchasse
Nov 14, 2011 08:08 PM
ahendy
Aug 25, 2008 03:03 PM
