16" Winter Steelies
Old Oct 7, 2020 | 10:00 AM
RocketJohn's Avatar
RocketJohn
16" Winter Steelies
Living in Colorado, and our Mini being delivered with summer tires last month, I decided to order up some winter wheels and tires.
Found on Ebay some 16" x 6.5" Black Steelies with 5 x 112 bolt pattern, +50 offset and 66.6 center hub. My question is, the center hole for a center cap is 2.5" which is bigger than the stock Mini caps. Any recommendations on what to put there? Or just run naked
I put some Conti Winter Viking Contact 7s on there in 195/55-16 size.
Old Oct 7, 2020 | 10:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
You're not going to get a center cap in that hub hole. That hole is there for the hub! They are winter wheels, run them bare.
Old Oct 7, 2020 | 10:52 AM
RocketJohn's Avatar
RocketJohn
Yes that makes sense for the hub., thanks!
Old Oct 15, 2020 | 04:19 PM
Walt's Avatar
Walt
OK, I am missing something here. Is the center hub hole on these wheels 66.6mm or 63.5mm (aka 2.5") ?
Old Oct 15, 2020 | 04:24 PM
RocketJohn's Avatar
RocketJohn
the center hub hole on the wheel is 66.6mm I forgot that the holes in the steelies are made to accommodate the actual axle hubs to fit through the wheel. And there would be no room for the standard mini Center cap for aluminum wheels. Needs more of a hub cab center cap, like VWs use.
TheAmericanJob
Tires, Wheels, & Brakes
Jan 10, 2017 09:12 AM
jmsamr
Oct 3, 2012 02:15 PM
sranderle
Jan 5, 2007 06:34 PM
UUNetBill
Aug 8, 2005 08:19 PM
