Suspension My rear sway bar fell off? Help
Old Dec 28, 2004 | 10:20 AM
leer's Avatar
leer
For the last few weeks, I've notice that my MCS is not as precise when turning corners and it also seem to sway (follow the groove) on the straight road. I've noticed that there are lot of creaking coming from my rear suspension).
Question - I had a RDR swaybar installed (in 2nd setting). I've look under the car and can't seem to find it. Should this bar be visible? Did I lose it? I certainly didn't hear it fall off.
Help, my car is not what it used to be.
Old Dec 28, 2004 | 11:13 AM
gowest's Avatar
gowest
I don't think it's possible for it to have fallen off, unless you lost the whole rear suspension and sub frame but it's possible an end link came loose or one or both of the pivot brackets has come loose or fallen off. Best way to check is to get under the car or pull the wheels off. There are pictures on this site that will help you find it, if you're still having a problem.
Old Dec 28, 2004 | 11:33 AM
sfjames2's Avatar
sfjames2
Look thru one of your rear rims. You should see it located just above and a little passed the brake disk. It did not fall out, that's impossible. Take it back to whoever installed if your not able to find the bar and the mounting locations to the subframe. Mine loosened at the subframe before, just tightened it back up. Hope this helps
Old Dec 28, 2004 | 12:18 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
also have the 3 bolts that hold the rear arm ( also for rear alignment ) checked, they may be loose and letting the car wander a bit. I saw a few people post here that they had wandering issues and one person had said thier bolts were loose and when tightened the wandering was better/gone. I just had mine aligned ( car has 500 miles ) and they werent as tight as they should have been and had been moving slighly already.
Old Dec 28, 2004 | 03:16 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Just wondering how you have something installed without knowing where it is and what it looks like. Hopefully didnt have someone else just install it because people here said it made it handle better
Have no fear though, there is no way it fell off. You have to remove your rear springs and on some cars you must drop the subframe in order to snake it out. My guess is it has something to do with alignment or the control arms.
Old Dec 28, 2004 | 07:03 PM
leer's Avatar
leer
found it. It may be loose
Thanks everyone. I had it installed by Helix.
As for not knowing what it looks like - Actually I don't know a lot of stuff and I've owned 7 performance cars over the years - but I know what I like and thats all it matters as far as I'm concern. Actually, if I didn't have to fill up so often, I probably wouldn't even know where to put the gas.
Cheers
Old Dec 28, 2004 | 07:09 PM
speltzer's Avatar
speltzer
Should look like this puppy...
or this...
Old Jan 6, 2005 | 03:33 AM
uae mini's Avatar
uae mini
The bushes might need some lubrication... after the second day I started to hear bad *** noises from them
don't have time to get them sorted .. but atleast I've got zerk fittings to finish the job faster.
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
