R50/53 belt keeps getting shredded
Old Sep 21, 2020 | 07:29 PM
rickyelias's Avatar
rickyelias
Installed new belt tensioner idler pulley and crank pulley. And its shredding the belt again. Any ideas?
Old Sep 21, 2020 | 09:02 PM
aboveliquidice's Avatar
aboveliquidice
Is your pulley completely seated and in line with the other pulleys? If it is out just a fraction, it will chew up a belt. It may also be too tight. Did you replace or move any other accessory components?
Old Sep 21, 2020 | 10:27 PM
rickyelias's Avatar
rickyelias
I just replaced the idler pulley belt tensioner and the crank pulley. As soon as I started the car, I heard a noise and it was the belt shredding on the inside edge
Old Sep 22, 2020 | 07:40 AM
Rarc45's Avatar
Rarc45
this was happening to me a few years back. turned out to be my supercharger pulley which was out of line. I would advise you check it if you have an aftermarket pulley installed.
Old Sep 22, 2020 | 08:06 AM
AngryScotsman's Avatar
AngryScotsman
This.
I have the WMW pulley that backed out a few cm and it shredded a belt. Then it kept kicking belts off.
Also, put a wrench on all of the pulleys to make sure they are tightened
rickyelias
Sep 24, 2020 08:27 AM
rickyelias
Sep 21, 2020 07:26 PM
weezer2282
Nov 20, 2016 06:13 PM
screwed36coupe
Oct 28, 2013 02:39 PM
purplehaze05mcs
Mar 27, 2009 04:21 PM
