R55 random stuff not working after clutch replacement.
Old Sep 19, 2020 | 10:58 AM
GrneEyeDog's Avatar
GrneEyeDog
Hi.
Bought 11 Clubman S with dead clutch, shop replaced clutch, flywheel , oil pan gasket, thermostat and valve cover gasket.
When I got the car back, idle was a bit rough, but after running it a little bit, it's getting better (probably very old gasoline) , anyway a few issues - turn signal do not self cancel, reverse light and fog lights are not working, window switch operation was reversed which I fixed it by turning window motor 180 degrees.
Before car was towed to the shop, all lights were working, what should I check? Is it FRM?
Thanks a bunch in advance!
Mister
Apr 18, 2016 05:20 AM
zamfield
Oct 14, 2014 05:19 PM
SoundMessage
Apr 19, 2013 11:16 PM
sjowol
Jan 15, 2008 06:15 PM
