Where is the starter motor in my 2012 R60 All4
Old Sep 18, 2020 | 03:19 PM
PhilJonze's Avatar
PhilJonze
Car was parked for 2 weeks.
When trying to start..all light, radio..ect work but pushing button to start the car only made some small electronic clicks (relays) and buzz/hum but engine wont start. Tested battery, it was low. Charged it. Still wont start (same results)
Attempts just drained battery again. Phisically checked battery, half the cells were almost empty. Clearly it wasnt in good shape.
Replaced battery, same result - now battery lower than 12.6v due to attempts to start.
so...i can charge this good battery back up...but need to LOCATE the STARTER MOTOR to look for corrosion...and maybe wack it a bit to see if i can get a start (after charging the battery).
Cant find ANYTHING online regarding the R60 starter!
Please help? Where is it located?
-long time follower, first time posting.
Old Sep 18, 2020 | 04:18 PM
mikey_t's Avatar
mikey_t
Starter is attached to the engine.... Did you register the new battery? That is the likely culprit.
Old Sep 18, 2020 | 05:13 PM
PhilJonze's Avatar
PhilJonze
Im not equipped with an IBS. So that rules that out.
Attached to the engine... I've worked on my vehicles before. Not a newbie. To be more precise..I was inquiry as to where exactly. Accessible from the bottom or top?
I couldnt slide far enough under to check the front properly...
Old Sep 18, 2020 | 05:57 PM
I_Forge_KC's Avatar
I_Forge_KC
It is under the intake manifold.
Old Sep 18, 2020 | 06:00 PM
PhilJonze's Avatar
PhilJonze
Thank you! I will check that out first thing tomorrow!
Ill report back on any progress! (Or failures..lol)
Cheers!
redlinedave
14
Jun 28, 2019 11:28 AM
sannweinstein
Mar 7, 2016 07:33 AM
MiniVespa
Classic Mini Talk
16
Oct 29, 2008 04:28 PM
BobCurry
Sep 9, 2008 02:36 PM
BVNitta
May 6, 2008 01:15 PM
