R50/53 Limp mode p1617 code
Old Sep 15, 2020 | 03:52 PM
chicolean83's Avatar
chicolean83
Good night MINI Family. I have an issue with my 05 Mini Cooper s. Started a few weeks ago when my car went into limp mode. Got codes P1617 h bridge dme, 0500 vehicle speed sensor, 1229 throttle body adaptation fault.
Replaced the throttle body and reset adaptation. Car drove well for about a week then went into limp mode. Replaced supercharger intake gasket as well as various others. During inspection of the car, I found oil in the twist connector on the drivers side fender. I’ve has a oil pressure leak which I have changed I just want to know if this could be causing my car to go into limp mode Intermediately due to oil in the harness. Thank you keep motoring!
Old Sep 16, 2020 | 09:34 AM
ssoliman's Avatar
ssoliman
Twist connector? Have a pic?
Old Sep 16, 2020 | 02:55 PM
nd-photo.nl's Avatar
nd-photo.nl
If you didnt create pics, can you point it out here > https://mini.7zap.com/en/mini/r53/co...-n-2006-0-ece/
Old Nov 13, 2021 | 07:12 PM
uriel's Avatar
uriel
Replace the throttle body and reset adaptation. Car drove well for about a week then went into limp mode. Replaced supercharger intake gasket as well as various others. During inspection of the car, I found oil in the twist connector on the drivers side fender. I’ve has a oil pressure leak which I have changed I just want to know if this could be causing my car to go into limp mode Intermediately due to oil in the harness. Thank you keep motoring!
hello friend I have exactly the same problem and the same codes could you tell me how
fullmoonguru
Jul 12, 2020 09:18 PM
maddog2020
Dec 1, 2019 10:00 AM
user 7398330
Mar 5, 2015 05:01 PM
Flyingfrenchman
Feb 11, 2012 10:54 PM
