F55/F56 DP and hard intake pipe install soon, what else while I'm there?
Old Aug 10, 2020 | 07:44 PM
NamBot3000's Avatar
NamBot3000
I'll be installing a Miltek downpipe and Forge hard intake pipe over labor day weekend. Is there anything else I should change or maintenance I should do that would be convenient while I'm that area of the engine bay?
Old Aug 14, 2020 | 08:35 AM
hadjiikong's Avatar
hadjiikong
You will have everything off to do spark plugs which if you are going to tune the car you will most likely need to change them anyway for the next step colder plug.
Old Aug 14, 2020 | 08:42 AM
NamBot3000's Avatar
NamBot3000
Good idea. I'm planning on upgrading my intercooler and doing a Stage 2 tune by the end of the year. What are the recommended spark plugs for that setup?
Old Aug 14, 2020 | 10:59 AM
curlywurly's Avatar
curlywurly
If you have the original motor mount i'd upgrade/change that out while you are under there
Old Aug 14, 2020 | 05:24 PM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
NGK Iridium
https://ngksparkplugs.com/en/part-finder
colder (8) SILZKGR8B8S
Old Aug 16, 2020 | 05:38 AM
sgscomps's Avatar
sgscomps
You can swap the intake pipe without taking everything apart that Forge shows. Save a lot of time buy popping the clamp and shown in the video
Just to be safe order the spring clip that holds the pipe to the turbo in case it falls. Also make sure you have some silver heat tape in case you tear the insulation on the firewall.
If you haven't ordered the intake pipe yet they have shown on backorder for a while. I got mine from ECS, I received an email they had them in stock and ordered right away, checked later that day and they were out of stock again.
Old Aug 16, 2020 | 03:51 PM
bluonyx's Avatar
bluonyx
That spring clip is a nightmare to get back on, when I go to Stage 2 and new downpipe, I'm definitely paying someone else to do it. With these times I don't mind paying to keep a good shop in business.
Mini_Vinnie
Jul 13, 2022 05:00 PM
tylerc
Aug 31, 2017 07:36 PM
Sbray
Feb 13, 2015 02:24 PM
SR20Fastback
Apr 18, 2013 09:56 AM
