R55 fuel problems
Old Jul 25, 2020 | 01:41 PM
Josh Libby's Avatar
Josh Libby
fuel problems
I have a 2012 r55 s. Car had problems starting and driving went in limp mode and now is dead. won't start at all. Had it scanned and was told it was the HPFP. Replaced it and nothing. Changed fuel filter and low pressure fuel pump and nothing. All fuses good as far as i know so are relays. Im new to working on mini"s. Where would one start and figure this thing out. Any help would be awesome. What scanner do people like to use that will work off their phone. Thanks and keep motoring
Old Aug 7, 2020 | 03:29 AM
MiniToBe's Avatar
MiniToBe
check for compression and spark.
check the ECU relays in the front. check the fuse box for water damage. remove the bottom connectors and see if there is corrosion...etc
Old Aug 7, 2020 | 05:35 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Either the Foxwell NT510 or the NT530 are the go-to scanners:
https://www.foxwelltool.com/wholesal...e-and-obd.html
https://www.foxwelltool.com/wholesal...0-updated.html
Jennifer Kintz
Sep 24, 2019 08:36 AM
MazMini
Mar 17, 2016 11:38 AM
VR6OhMy
Apr 30, 2015 04:26 AM
Han Solo
Nov 21, 2013 06:57 AM
minibp
Nov 29, 2010 04:35 PM
