JCW NM Power Module "WOW"
Old Jul 17, 2020 | 09:53 AM
miniwheels's Avatar
miniwheels
Installed NM Power module in my 2015 JCW f56, automatic trans,
In the 91 octane setting even eco mode, amazing power!
I am getting 35.6 mpg, 84 mile total commute over 3 weeks cruising at 70 -80 mph almost the whole commute. When put it sport (go kart) mode can spin the tire in 2 gears accelerating!
I have Borla Axle Back sport exhaust, no drowning sound, pops nicely, Dinan Carbon Fiber Air Box. Running Pirelli stock size run flats.
Old Jul 18, 2020 | 02:21 PM
TVPostSound's Avatar
TVPostSound
Should have bought a DInan module, for the Badge!!
Old Jul 19, 2020 | 06:18 AM
ASKtheteach's Avatar
ASKtheteach
I have one on mine and it does make a huge difference. For even more fun, pair it with a Sprint Booster. I added one to my car a couple of weeks ago. It doesn’t add any power, but it dramatically increases throttle response. The result is that the car feels ridiculously fast. It is actually possible to bark the tires in first, second, and third gear.
Old Jul 22, 2020 | 07:42 AM
madmix's Avatar
madmix
Add a pedal commander, it even adds more fun.
Old Jul 30, 2020 | 11:12 AM
KYDan's Avatar
KYDan
If you add TORCO, Boostane, or whatever octane booster you want to achieve higher octane fuel and switch the module to that setting you will get even more horsepower and torque. I have not used it in several years, but the seat of the pants feeling and tire spin validated that it worked. Or, if you can get your hands on 105 octane fuel that will work as well. I did not use it very much as I was concerned that it might damage the engine or powertrain. BTW, I had it dynoed on the standard power setting with 93 octane Shell and it produced 270 horsepower.
Old Aug 5, 2020 | 03:18 PM
rbm416's Avatar
rbm416
The NM Power module gets rid of the irritating lack of response from a stop. No need for other gimmicks to get better throttle response. Just finished a track day, 92 octane full set to the low setting and it was a good day.
Old Aug 19, 2020 | 03:54 AM
miniwheels's Avatar
miniwheels
Honeymoon Over!
All of the sudden, No Power, gauges flutuating slightly...NO CEL, car feels like is running in ECO mode but with less power.
removed NM power module still the same. Will a reflash of ECU bring it back to life?
Old Aug 19, 2020 | 05:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
removed NM power module still the same. Will a reflash of ECU bring it back to life? There are no other systems...just a lazy car.
A friend of mine has an NM power module on his F56 S, and it caused some codes last fall. He had to remove the module and clear the codes for the car to return to normal.
​​​​​​​Have you tried clearing the codes after removing the module to see how it runs? Do you have a BMW/Mini code reader to find any hidden codes?
Old Aug 19, 2020 | 05:25 AM
graff48's Avatar
graff48
Try disconnecting/reconnecting the battery to reset the ECU.
Old Aug 19, 2020 | 06:23 AM
miniwheels's Avatar
miniwheels
I removed power module....last night...drove to work still no power... speedo tach are acting funny....no cel or warning symbols....can still do 70 just no power...
​​​​​Will try to disconnect battery...
Old Aug 19, 2020 | 06:24 AM
miniwheels's Avatar
miniwheels
Do not have a code reader...have a appointment with dealer tommrrow....
madmix
Dec 29, 2019 08:18 AM
Doc9point5
Aug 5, 2019 05:42 PM
tylerhunter
Jul 22, 2018 10:09 AM
_ynot
May 26, 2018 04:52 PM
tylerhunter
Mar 19, 2018 04:46 PM
