R50/53 when should the condenser fan come on?
when should the condenser fan come on? I have a 2006 Cooper S. The A/C isn't as cold as it should be and I noticed that the condenser fan isn't running the whole time the compressor is engaged.
I believe it should run when you turn on the airco (dont know for sure though). If it isn't cold, then do an airco check. Probably needs a refill, I think a refill also means that a pressure test will be done.
R50/53 Another cooling fan thread
50shadesofr53
Aug 23, 2016 05:20 PM
