R50/53 Cylinder misfire, no compression on cylinder
Old Jul 10, 2020 | 08:34 PM
Jerry Balch's Avatar
Jerry Balch
Hi everyone,
I am tracking down a misfire that isn't spark, fuel, or air.... The cylinder with the misfire has no compression... I took the valve cover, and rocker arms off thinking maybe I could find or see a broken valve spring. Do I need to remove the springs to tell if they are broken? They all "look" good from what I can see... I am hoping to avoid pulling the head but am not opposed to it if I need to.
Any help or suggestions would be appreciated. This is a 2004 JCW R53 with 130k on the clock.
Thanks!
Old Jul 12, 2020 | 05:37 AM
thomm's Avatar
thomm
If you check the valve springs closely, you can see if the springs are broken or not.
I think that a burned valve is a more common issue.
Old Jul 12, 2020 | 05:59 AM
Mike87's Avatar
Mike87
To verify the valve(s) are the problem, do a leak down test.
Old Jul 13, 2020 | 09:27 AM
Jerry Balch
Thanks for the tips. I have inspected the springs very closely and they appear to be just fine. I will do a leak down (well, have someone do a leak down test). Thanks for the help!
Old Aug 29, 2022 | 03:53 PM
CdnR53's Avatar
CdnR53
In case it helps, I just discovered a broken intake valve spring only after looking at it several times. It is broken right at the bottom so it was hard to see. It has worn a little hole in my spark plug tube which is what got me looking. Strangely I have not had any major symptoms.
FrankBlack
R55 :: Clubman Talk (2008+)
Nov 5, 2019 10:22 AM
Etmil35
Dec 18, 2017 10:24 AM
mjcari
Jun 12, 2016 07:03 AM
Streakerr
Jul 16, 2013 08:51 AM
nethack
28
Apr 26, 2013 01:52 PM
