R56 2007 Base - Front Caliper Rebuild seals?
Old Jul 8, 2020 | 02:07 PM
ViralTypo's Avatar
ViralTypo
I want to rebuild the front calipers on my R56. The passenger side caliper keeps sticking. I've pushed it out (most of the way) and cleaned/lubed it a couple times now which just temporarily stops it from sticking. I can't find the seals for the life of me. Not ones that I am 100% sure are right. I found Raybestos WK2020 on Amazon but it has 294mm rotor in the notes. Are the calipers the same on models with 280mm vs 294mm rotors? I'm assuming the 294mm rotors are the Cooper S?
Old Jul 8, 2020 | 05:51 PM
Lancaster's Avatar
Lancaster
Good question - ECS (our host) should be able to point you in the right direction. Let us know what you find. Those Wisconsin winters must be really tough on the caliper pistons. I had a Volvo once that did the same thing. For some reason the caliper pistons just turned to rust.
Old Jul 8, 2020 | 05:59 PM
ViralTypo's Avatar
ViralTypo
The car was given to me. I'm not surprised the caliper pistons had a film of corrosion/rust on them because when I flushed the brake fluid out it was BLACK! Probably 13 years old just like the rear brakes I had to replace.
I decided to just order some rebuilt calipers for the front. I really don't want to mess with rebuilding them and by the time I buy new pistons and seals I could have almost bought one of the calipers...
MrBlah
Apr 19, 2018 07:17 AM
PhoR53
Jun 5, 2015 01:25 PM
p8ntbollr
Aug 6, 2013 09:28 PM
scotwilson4403
May 29, 2013 06:12 PM
