R50/53 Car Starts Shaking at about 68 mph
Old Jun 23, 2020 | 07:47 PM
Stripeknight's Avatar
Stripeknight
My 2005 Mini Cooper S has about 42,000 miles and it starts to shake when approaching 68-70 mph, I assumed it was the balance of the tires but I took it to a shop today and they claim it's the front control arm with bushings, they pushed a rod into the assembly and wiggled it around claiming it was loose.
They want $1,200 to make the repair and claimed they are the only shop in the city with an "alignment rack" that is needed to finish the job.
Are there other shops in San Diego that are recommended and does this seem like the real issue?
Thank you!
Old Jun 23, 2020 | 10:22 PM
RB-MINI's Avatar
RB-MINI
Not sure if it’s causing your issue, but front control arm bushings are definitely a problem on these cars. The stock FCA bushings don’t seem to last very long, and Power Flex street version urethane bushings seem to be the popular replacement when not going with stock bushings.
A few other causes could be non-hubcentric or bent wheels, bad tires or balance, and shake from axles after lowering.
It can be expensive to do the job “right” without shortcuts like cutting the old bushings out, but $1,200 still sounds high. Also not sure what special alignment rack is needed. Hopefully Way Motor Works can provide some info on this repair.
Old Jun 24, 2020 | 05:27 AM
user 7389739's Avatar
user 7389739
At which point, with a perfectly straight face, you politely thanked them for their input, got back in your car, and drove away...right?
Old Jun 24, 2020 | 06:35 AM
nd-photo.nl's Avatar
nd-photo.nl
1200 bucks is way too much for the work stated. I hope you followed the advice from RedSky455!
Old Jun 24, 2020 | 09:17 AM
Stripeknight
That's exactly what I did.
Old Jun 24, 2020 | 09:35 AM
Stripeknight
Does anyone have a legitimate shop in San Diego they can recommend? Should I order the parts directly?
newninja
Apr 30, 2012 02:04 PM
mustgetwet
Jun 16, 2011 07:24 AM
kaneguy
11
Apr 20, 2011 02:05 PM
rnelsonee1
Suspension
Aug 21, 2009 07:53 AM
staz87
Jul 22, 2009 01:43 PM
