Lug bolt length with aftermarket wheels
Old Jun 21, 2020 | 05:40 PM
smlzilla's Avatar
smlzilla
Hey everyone
i found somewhere that the stock lug bolt length for the GP2 is 27mm. GP2 wheels are 17x7.5 45et. My aftermarket wheels are 17x7.5 35et. What length conical lug bolts do i need? 37mm lug bolts? Please confirm.
thanks everyone
Old Jun 21, 2020 | 05:55 PM
gowest's Avatar
gowest
The offset of the wheels (+45 vs +35) does not affect the length of the bolt needed. The only things that affect that are, if you use spacers or are changing from thin, usually forged wheels, to more normal wheels.
Old Jun 21, 2020 | 06:04 PM
smlzilla's Avatar
smlzilla
so your saying I can use conical lug bolts in stock length 27mm?
Old Jun 21, 2020 | 07:13 PM
gowest's Avatar
gowest
Yes, but if never hurts to count the number of turns, that the bolt is engaged. Put it in just enough to catch the first thread, then count the number of turns it takes to get it torqued down properly. You should have at least 7.5 turns of thread engagement.
Old Jun 21, 2020 | 08:58 PM
MVPeters's Avatar
MVPeters
Just put a lug bolt through an 'old' wheel & see how much it sticks out the back
Repeat with a 'new' wheel. If it sticks out the same amount, you're OK.
Old Jun 21, 2020 | 09:37 PM
smlzilla's Avatar
smlzilla
I wish it was that easy. I currently have a stud conversion so I just want to get the right length bolt so to will be a seamstress swap.
Old Jun 21, 2020 | 09:51 PM
MVPeters's Avatar
MVPeters
Then just try a new wheel on the old studs - same difference.
or just measure the thickness of the wheel centers.
The general rule is that you should be able to see 1 or 2 stud threads outside the nut.
chilimac
Aug 17, 2009 08:59 AM
Giants9595
Tires, Wheels, & Brakes
Nov 7, 2006 10:00 AM
Giants9595
11
Nov 2, 2006 09:33 AM
gstockmini
Apr 11, 2005 06:50 PM
gr8britwjh
Dec 13, 2004 04:58 PM
