R50/53 Water pump flange o-ring material
Old Jun 8, 2020 | 06:07 AM
GearheadS's Avatar
GearheadS
Hey Folks,
The Water Pump flange on the R53 has two identical o-rings, one against the block and one against the WP outlet. Are the factory ones any kind of special material? Or just standard Buna / nitrile?
Also, why do people replace the flange? What happens to the old one?
Thanks!
Old Jun 8, 2020 | 07:39 AM
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
I have no idea about the material. But from doing a WP install I would say buy a stocker. You dont want the gasket to roll out of the groove on the water pump when you push it into the connector. In my case
I bought a new connector since the flange on mine had corrosion on it and looked like it was leaking onto the block (it was rusty underneath it). Think the corrosion on them is a common problem.
Old Jun 27, 2024 | 06:52 PM
R53Fresh's Avatar
R53Fresh
O ring
I know this is old but I was digging around and spoke to the parts rep from advanced and they cross referenced the oring for the flange to block and it’s number is 35965
r52pimp
21
Oct 28, 2024 05:18 PM
ryanleeis
Sep 3, 2012 08:36 PM
Neufusion
Jul 12, 2011 04:13 PM
Boosted_Mini
May 18, 2011 07:49 AM
