Alignment specs for new tires? Toe, Camber, Caster
Old Jun 7, 2020 | 01:17 PM
Michaelh57's Avatar
Michaelh57
I’ve been looking online and can’t find any specs for the oem camber, toe, or caster for a Mini Countryman s 2012. Is there a recommended amount for these from the factory? Looking at my car from behind the toe on my back left wheel appears to be off compared to the right. I’m planning on getting new tires soon and wanted to find out the specs I should have them aligned to.
The tires I’m looking at are the Vredestein Quatrac 5.
I’m mainly considering them due to the price $457 for 4 and the numerous good reviews. If anyone has tires for a similar price please let me know and how you’re liking them, or if anyone is running these.
Old Jun 8, 2020 | 03:51 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Here ya go!
https://www.newtis.info/tisv2/a/en/r...ement/EGsZv90G
Old Jun 8, 2020 | 10:40 AM
Michaelh57's Avatar
Michaelh57
Thank you for that chart it’s appreciated. If I show it to the shop will they understand it or do I need to say I want certain number?
Old Jun 8, 2020 | 11:04 AM
cristo's Avatar
cristo
Alliance Member
I’d ask for front and rear toe at
about half the numbers listed,
front camber about even left to
right and near the upper part
of the range (closer to -60’), rear
camber about even left to right
and nearer to the lower part of
the range listed (closer to -1,20’).
Dont worry about caster, can’t do
much about it anyway.
Old Jun 8, 2020 | 11:08 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
They should understand it. Also, make sure you get a print out with the "After" numbers.
Most important thing to look for, is that the right side numbers are as close as possible to the left side numbers - you want the right and left side to be THE SAME. Also, make sure you have toe IN on the front and back, not OUT.
Old Jun 8, 2020 | 11:35 AM
Michaelh57's Avatar
Michaelh57
Ok thank you all for the help I really appreciate it. I don’t know very much and everyone on here is always really helpful
Systemlord
May 13, 2014 07:49 AM
or birdman
General Discussion
May 29, 2011 06:33 AM
BourneAgain
Apr 22, 2011 04:07 PM
corin.mcblide
Sep 24, 2010 08:49 PM
stanleys06
Nov 18, 2007 08:29 PM
