R55 Where does this part belong?
Old Jun 2, 2020 | 04:04 AM
Dan_C_in_NJ's Avatar
Dan_C_in_NJ
Hello All,
I am finishing my work on the Mini and have a small issue. The car is back together but I have a part I don't remember where it resides. I hope someone can lend a hand and point me in the right direction.
Thanks in advance.
Dan
Old Jun 9, 2020 | 04:16 PM
Dan_C_in_NJ
Okay. I was able to find the location for this piece. I have an EVAP error: "EVAP System Purge Control Valve "A" Circuit Open".
I was removing the stock air box to check all the connections near the Intake Manifold when I found the location. So two questions:
1) Does anyone know what this part does? I see no reason for it's placement or use. I am stumped.
2) As I had no evap error before teardown and it's there now, where should I start? I plan on checking voltage for the connection near the charcoal canister but not sure where to go after that.
Any help would be appreciated.
Thanks in advance.
Dan
Old Jun 9, 2020 | 05:18 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I was going to say it looks like a wiring harness clip
Old Jun 9, 2020 | 07:43 PM
Dan_C_in_NJ
njaremka,
I thought that as well but I remembered taking it off a part but no wires were around.
Due to my EVAP error I checked out the Bentley manual (page 130-32) and saw the clip on the Throttle Body.
So I removed the Intake off the N-14 to look at the location of this clip but also the vacuum / evap routing.
The clip fits into a slot in the housing of the bottom, external surface of the throttle body.
The slot has no function I can see other than to hold this clip. No orifices to cover or section to hold in place. Just a slot.
I am open to any explanation.
Phobic
Classic Mini Talk
Aug 19, 2014 06:16 PM
raytay112
Mar 5, 2012 02:23 PM
DanielleLita
Apr 3, 2011 01:11 PM
fanta
Dec 4, 2010 05:38 PM
windsorlove
Off-Topic :: Autos
12
Jun 3, 2008 12:37 PM
