Oil leak
Old May 15, 2020 | 10:32 PM
Scooter24's Avatar
Scooter24
Oil leak
I did a oil change on the car and noticed oil on the trans towards the back of the motor. I can't see where it's coming from and I haven't had time to pull the air cleaner box to get a better look. Valve cover is newer and isn't leaking. Any advice would be great. 2011 MCS.
Old May 20, 2020 | 03:30 AM
Lancaster's Avatar
Lancaster
Unusual. I would suspect the oil filter housing as it seems to come from the front engine side. I'm sure you looked as much as you could. Other than that, engine seal (the one behind the pressure plate)?
Old May 20, 2020 | 10:37 AM
thebombardier's Avatar
thebombardier
Possible that the starter itself is leaking. I believe it's an oil encased motor. Have you noticed the starter motor making more noise when engaged?
Old May 20, 2020 | 10:48 AM
Scooter24's Avatar
Scooter24
nope, starter makes no noise and car fires up like normal.
Old May 20, 2020 | 03:20 PM
cpmetz's Avatar
cpmetz
Maybe the o-ring of the fuel pump, or vacuum pump combined with parking on an incline?
Old May 20, 2020 | 03:25 PM
Scooter24's Avatar
Scooter24
I was just thinking about the fuel pump. Ill have to dig into it here in the next few days. The fuel pump is only a little over a year old so I wouldn't think it would be it but very well could be.
Old May 21, 2020 | 07:35 AM
schovil69's Avatar
schovil69
Are you seeing oil on top of the tranny?
prmspen
May 28, 2020 06:53 PM
eaglebeagle
R60/R61 Stock Problems/Issues
Oct 23, 2018 02:17 PM
carterR50
Oct 17, 2012 11:11 AM
BillyCuth
Apr 3, 2012 08:49 AM
