r56 2007 MCS another idle problem
Old May 15, 2020 | 10:41 AM
kokosiqqq's Avatar
kokosiqqq
Hello there, I've been looking for solution for few months and finally decided to ask here maybe someone had same problem and can help.
I've got r56 2007 MCS and I've got idle speed fluctuations (it's not as bad as rough idle videos on YT, it doesn't stall, I'd say 50-100), sadly there are no stored faults, here's what I've done so far:
- turbo rebuilt
- new intake pipe (helped a bit)
- new timing chain set
- valves cleaned
- vanos solenoid cleaned
- non return valve cleaned
- TB cleaned
- new plugs, battery, alternator, HPFP and maybe something else I've forgot to mention
When I turn AC on as RPM go a bit higher it makes fluctuations less noticeable.
I've been to few independent shops but with no success.
Any ideas? I'm clueless.
Old May 22, 2020 | 06:31 AM
MiniToBe's Avatar
MiniToBe
I had a similar issue back in the day and it was a fuel injector stuck open.
Old May 22, 2020 | 07:33 AM
kokosiqqq's Avatar
kokosiqqq
did you get any codes for that?
Old May 22, 2020 | 07:39 AM
MiniToBe's Avatar
MiniToBe
I dont remember i got any codes to be honest which made it frustrating at the time.
I discovered it when I removed my plugs for some reason and noticed gas pooling in one of the cylinders after sitting for a day or so.
Old May 22, 2020 | 07:50 AM
MiniToBe's Avatar
MiniToBe
I found the video i took back then lol
Old May 22, 2020 | 08:15 AM
kokosiqqq's Avatar
kokosiqqq
https://youtu.be/L6QgtY1Hvgs
mine sounds less rough but i’ll take a look anyway, thanks for ideas
Old May 24, 2020 | 03:15 PM
GsxR1000's Avatar
GsxR1000
Hello,
I'd suggest you check the PCV tube, that runs from rear-passerger side of vavle cover to intake. If this plastice pipe has a crack, there will be a vacuum leak which will cause idle issues.
Good luck
Old May 25, 2020 | 09:44 AM
kokosiqqq's Avatar
kokosiqqq
small update, today i finally got 2 codes related to superknock (i've got cheap reader but its a clue) so faulty injectors are possibility, i hope it will be fixed finally
i will get back with update later
Originally Posted by GsxR1000
Hello,
Good luck
i've replaced whole valve cover with pcv tube last year so it's not likely the cause but thanks for idea
Old Jul 8, 2020 | 12:06 PM
kokosiqqq's Avatar
kokosiqqq
if someone is interested what happened to my car sadly it was cracked piston
Old Jul 8, 2020 | 12:12 PM
MiniToBe's Avatar
MiniToBe
sorry to hear that bro...is the cylinder wall still in good shape?
Old Jul 8, 2020 | 12:27 PM
kokosiqqq's Avatar
kokosiqqq
I've got it fully rebuilt already resleeving included,
i'm during break-in period now, hope i will have some trouble free miles
Old Jul 8, 2020 | 12:34 PM
MiniToBe's Avatar
MiniToBe
That's awesome bro...how much the sleeving cost you? I was quoted i think 600-800 a cyl!!!
Old Jul 8, 2020 | 05:58 PM
Lancaster's Avatar
Lancaster
Can you please share the details - what was done, how much did it cost, length of time, upgrades or "while-you're in there" stuff?
Davbret
55
Mar 10, 2019 03:04 AM
Ixx
Jul 11, 2017 07:09 AM
Steven_RW
Apr 12, 2015 03:53 PM
Nui
Feb 14, 2014 05:34 AM
btallack
Apr 14, 2008 05:46 PM
