R50/53 Should I have this?restrictor? in the coolant return line?
Old May 13, 2020 | 08:44 PM
AndrewVanis's Avatar
AndrewVanis
Doesn't look stock, doesn't show up on RealOEM. Does it serve any function?
Old May 14, 2020 | 05:07 AM
Mr_Stop's Avatar
Mr_Stop
Is your car an R50? That may be a bleeder for the the coolant. I think I recall seeing that the R50 has a bleeder in that location in the Bentley manual.
Old May 14, 2020 | 07:24 AM
AndrewVanis
I have a R53 . It is not a bleeder valve
Old May 14, 2020 | 08:03 AM
gumbedamit's Avatar
gumbedamit
Looks like this hose was cut and plugged..
Old May 14, 2020 | 08:05 AM
AndrewVanis
it flows. the hose from the top of that to the reservoir is removed for the picture
Old May 14, 2020 | 06:27 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
No that is for sure 100% not factory, nor are any of those clamps so someone has been in there changing things up.
I'd just remove it and install the correct hose going from the T to the Coolant tank.
Michaelh57
R60/R61 Stock Problems/Issues
Apr 27, 2020 04:18 PM
CooperSPT
Feb 26, 2020 02:37 PM
LethalR53
Jun 9, 2013 08:32 AM
RECOOP
Jul 19, 2004 03:32 PM
