F55/F56 F56 Front Sway Bar Links Install Instructions?
Old May 6, 2020 | 04:48 AM
2door15's Avatar
2door15
Does anyone have a link to or a write up on how to install front end sway bar links on an F56? Tools required, etc... Thanks.
Old May 6, 2020 | 08:44 AM
lonewolf170's Avatar
lonewolf170
Allen key set and meteic wrench set. Use Allen key to hold bolt, use wrench to take off nut.
Old May 7, 2020 | 07:27 AM
MikeMJCW's Avatar
MikeMJCW
After jacking up the car you then jack the rotor assembly independently to un-tension the sway bar. You'll see the end link bolt start to square up as it de-tensions i.e. no load.
TVPostSound
Dec 21, 2019 11:41 AM
RDSJCW
Aug 6, 2017 07:44 AM
PatM
Jul 28, 2015 08:02 PM
R99
Feb 19, 2015 03:54 PM
