R50/53 Electrical mystery???
Old Apr 22, 2020 | 08:46 AM
Moflash1's Avatar
Moflash1
Late 2006 R53 build.......Ac compressor,Radiator fan,power steering fan all are inoperative.Checked and tested every fuse on interior kick panel and under bonnet fuse panel.switched relays around,checked all connections including grounds.Power steering fan spins freely by hand.They all seem to be getting no power? Is there a hidden fuse?Perplexed,any ideas???
Old Apr 22, 2020 | 12:07 PM
Check the main fused under the main panel, i had a main fuse that had a hairline crack in it. Also the main cable going from battery to the starter to the alt. The connection at the starter is ones that can be an issue.
Old Apr 22, 2020 | 12:14 PM
Moflash1's Avatar
Moflash1
Where is the main fuse under what main panel? Sorry cant picture your described location?
Old Apr 22, 2020 | 12:37 PM
Front fuse box near the intake
https://www.northamericanmotoring.co...nd-wiring.html
https://www.northamericanmotoring.co...-is-there.html
Old Apr 22, 2020 | 12:43 PM
Moflash1's Avatar
Moflash1
Thank you,I will check that.
Old Apr 22, 2020 | 12:45 PM
Welcome.
lordgrinz
Jul 27, 2015 11:03 AM
Jason Garrett
Feb 14, 2014 06:54 AM
bustadons
Sep 3, 2010 01:25 PM
mini4usa
May 23, 2003 11:18 PM
