R50/53 Air conditioning - AC noise/problem.
Old Apr 12, 2020 | 09:21 AM
Paweł Krzyżański's Avatar
Paweł Krzyżański
Hey, i have problem with my car - 2006 mini cooper S JCW.
When i stop the car i hear this noise from movie until car move. Can some 1 help me? Inpa shows no errors. Air when i drive isnt super cold.
Old Apr 14, 2020 | 06:13 PM
Mr_Stop's Avatar
Mr_Stop
AC clutch maybe?
Old Apr 14, 2020 | 07:20 PM
cooper48's Avatar
cooper48
+1 ... Definitely your AC clutch kicking in making that noise. The clutch itself can be replaced without having to replace the entire compressor. The clutch can be tricky to get off the compressor sometimes depending on how long it's been on the car but it's not a difficult repair. Be careful and don't damage the bolt holding it to the compressor. You can however buy a remanufactured compressor with a 1-year warranty for less than $100 online. Of course, that would require a freon recharge, etc. (~$90). That's what I ended up doing because the bolt head broke off mine when I tried to remove it (been on the car for 15 years). Good luck.
Old Apr 14, 2020 | 09:50 PM
Paweł Krzyżański
but i hear it only inside the car and it blow not cold but not warm. If i run its colder, and making no noises. When i drive i feel colder air.
Old Apr 15, 2020 | 05:24 AM
Mr_Stop's Avatar
Mr_Stop
It's weird that you just hear it inside the car. I just replaced my AC clutch and it briefly made the sound in your video as it "broke in." It sounds like your clutch is slipping while the AC is on. It may be from a worn clutch or the the coil. You can view the AC clutch action with the engine running. We could be completely wrong as it's hard to diagnose via the internet, but it's worth looking into this part.
I bought a new clutch for about $50 off of ebay and it's a fairly simple repair. Just make sure you install the included "shims." I didn't on my first clutch and burnt it up. Here's some how to resources:
https://www.northamericanmotoring.co...utch-coil.html
Old Apr 15, 2020 | 09:41 AM
Paweł Krzyżański
i check ressistance - 3.9 ohm
Old Apr 20, 2020 | 08:29 AM
Paweł Krzyżański
Problem solved - AC CLUTCH work fine, only half of freon was in the system. After refill works perfekt
Old Apr 20, 2020 | 11:39 AM
Mr_Stop's Avatar
Mr_Stop
Glad you got it figured out!
Kevlar7R
May 16, 2024 07:45 AM
Fizzyx
Aug 14, 2015 08:24 PM
Rascasse
Jul 20, 2008 01:31 PM
paulo500
May 31, 2006 01:26 PM
THE ITCH
Nov 10, 2005 11:38 AM
