Rear Suspension Creeking/groaning noise going over bumps
Old Apr 10, 2020 | 10:13 AM
geekd4d's Avatar
geekd4d
Ok, So I'm 9 months into my Mini countryman ownership and this month's problem is: (drum roll please)
I'm not getting a creeking/groaning noise when I go over bumps coming from the rear end.
I had just replaced the rear sway bar bushing due to a nice clunking noise from the rear, the clunk is gone, but now there's this groan/ creeking noise. (that's the only way to describe it. like an old bed or couch)
the struts seem to bounce just fine when rocking the car..
Going to take it all apart next week to put new bearings in, what should I be looking for?
Old Apr 10, 2020 | 10:30 AM
cooper48's Avatar
cooper48
Poly sway bar bushings? Did you lube them? If not, that may be your noise. Also, check the end links to ensure they're bolted in properly (correct torque spec).
Old Apr 10, 2020 | 12:05 PM
geekd4d's Avatar
geekd4d
oooooh I did not lube them! (I've only used ones that had zerk fittings on them on past cars)
Inside? outside? both?
I was going to replace the links while I was swapping out the bearing hubs while I had everything apart for good measure. (already ordered ones with zerk fittings)
These were the ones I got - Not the super stiff poly ones. 16mm ones.
Old Apr 11, 2020 | 08:27 AM
cooper48's Avatar
cooper48
Not a big deal to pull the sway bar bushings and lube them inner and outer to see if that solves your problem. I have poly bushings throughout the rear of my R53 and they do make noise when dry.
Old Apr 11, 2020 | 09:30 AM
geekd4d's Avatar
geekd4d
Exactly! great thought!
Going to try this hopefully tomorrow or Monday if not when it actually gets into the 50s
thanks!
Old Apr 14, 2020 | 10:56 AM
geekd4d's Avatar
geekd4d
That was it!
Took the new ones out, greased them and popped em back in.
Noise is now gone!
Thank you! I wouldn't have thought to grease em if they didn't have the zerk fitting.
Old Apr 14, 2020 | 06:30 PM
mikey_t's Avatar
mikey_t
My rear sway bar bushings were getting a bit creaky over bumps and lubricating them did the trick.
Old Apr 14, 2020 | 07:13 PM
cooper48's Avatar
cooper48
You're welcome. Glad I could help since I've received so much help on this forum myself.
jpwins
Oct 14, 2016 09:48 AM
mikeson
Feb 11, 2014 07:58 PM
creddylad
Mar 2, 2011 04:26 PM
Raoul5050
36
Feb 6, 2009 07:44 PM
Verruckt
Suspension
43
Aug 9, 2007 09:17 PM
