R50/53 Midland Issues After Rebuild
Old Apr 4, 2020 | 12:20 PM
Ethan E's Avatar
Ethan E
Hello, I am new to minis and new to NAM. I recently purchased an 02 MC. It ran but needed a new clutch. I swapped the clutch and also decided to do a full bearing overhaul for the transmission. I reassembled and started the car and I can not release the clutch in neutral because it stalls. It goes into all gears and drives, but neutral does not seem to work anymore. I pulled the transmission again and manually set it to neutral and spun the input shaft by hand. I noticed the diff splines rotating as if neutral isn't working. I am just wondering if anyone else has had this issue with their Midland or if anyone has any clue what the problem could be.
Thanks,
Ethan
Old Apr 8, 2020 | 11:00 AM
PoonRacing's Avatar
PoonRacing
contract http://www.jontheminiguy.com/ he might able to help you out with question
Old Apr 10, 2020 | 08:25 AM
+1 or check out this:
https://www.northamericanmotoring.co...mentation.html
Ethan E
Apr 3, 2020 04:35 PM
skyline4eva
Mar 30, 2014 07:03 PM
Mannylove
Jan 19, 2013 07:58 AM
saxman
May 25, 2007 03:45 PM
