E-Mini (2020+) Electric Mini Discussions
E-Mini What Home Charging Equipment Are You Using?
Old Apr 3, 2020 | 06:40 PM
Hogan3's Avatar
Hogan3
(assuming you do charge at home)
Old Apr 4, 2020 | 10:37 AM
MiniAndo's Avatar
MiniAndo
My dealer is using BMWs charger (logically).
$1000 is about what I expected to pay for one of these, but I haven't done much research. There's something nice about staying OEM though. That will be my plan if we pick up an SE.
Old Apr 5, 2020 | 07:11 AM
jamez's Avatar
jamez
ChargePoint for me. Up here it is 240v at 32A. I have a very long cable for it that I actually snaked through my foundation (so I could have the EVSE in the garage and the plug outside).
I documented it over at my EV help page:
Facebook Post
Old Apr 5, 2020 | 09:01 PM
a-fung's Avatar
a-fung
Interesting installation. I am curious why you have just the cable outside. Is it lower cost? Or simply the cable is too long?
Old Apr 6, 2020 | 05:42 AM
jamez's Avatar
jamez
Having the EVSE outside was going to leave it exposed to the elements (even though it is weather rated), as well as creating a tricky exterior NEMA 14-50 solution. By installing the EVSE inside, It should last much longer, and the cable is modular and replaceable. Others shove them under the garage door, but I don't want to give rodents any more possible avenues to enter.
Old Apr 6, 2020 | 06:14 AM
Hogan3's Avatar
Hogan3
Smart!
Old Apr 7, 2020 | 09:34 PM
Jumpmini's Avatar
Jumpmini
Was able to get a JuiceBox 32 Next Gen installed maybe a week before we went into lockdown here. Works okay, but it doesn't seem as "smart" as I was expecting. Like, I can't seem to tell it, "Have the car charged to 90% by 7am, and start charging whenever is necessary to make that happen just in time."
I can schedule it myself, though, which is fine, but I thought it would be smarter.
Old Apr 8, 2020 | 05:20 AM
Hogan3's Avatar
Hogan3
Don't know a lot about EVSE's, but can any of them "predict" charging time?
I assume it varies by vehicle, battery condition, temperature and perhaps other factors, so that what you are asking is not possible.
But keep in mind I don't own one yet, and perhaps don't know what I'm talking about :-)
Old Apr 8, 2020 | 07:44 AM
MiniAndo's Avatar
MiniAndo
It was my understanding that this sort of thing is controlled on the vehicle side. The charger supplies as much or as little as the car is asking for. You are correct that it would be an insurmountable task to teach the EVSE about the intricacies of every vehicle on the market, but teaching an EVSE to "listen" well should be trivial.
As an aside: JuiceBox is a wonderful brand name for an EVSE.
Old Apr 8, 2020 | 11:19 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
BMW/MINI misses the gist of intelligent battery charging. It is pretty evident in the implementation of the IBS system for keeping your battery charged in gas powered vehicles. The system is supposed to be intelligent/smart and yet you have to tell it when you put in a new battery. My $20 Duracell battery tender has the brains how to taper charge a battery as do many other charges under $100. So why BMW can't get it right is a question that I can't answer. It's obvious that the circuitry is pretty inexpensive.
Guess I'll be waiting for another year at this point before going electric.
Old Apr 8, 2020 | 01:38 PM
Hogan3's Avatar
Hogan3
I'm under the impression many new cars have that requirement today
because the car's charging strategy varies depending on the exact capacity of the battery as well as it's age.
Not sure if it has to do with AGM batteries, trying to maximize the life of a battery, or minimizing fuel mileage by making the alternator work as little as possible or a combination of these, or other things. How else would the car know the capacity of the battery and it's age?
Your $20 battery tender does not have the ability to tell the age and capacity of you battery either.
Old Jun 14, 2020 | 08:39 AM
F14Scott's Avatar
F14Scott
Tesla HPWCg2 and (probably) this EVSE J1772 adapter
We have a Model 3, and I just made this cable holder so my wife can park the car forward on the right-hand side of the garage, because her charging port is port aft. When my Mini comes, with its port at the starboard aft, we'll be able to share the charger, if I get an adapter like this one:
https://www.evseadapters.com/product...nt=36339297937
The High Power Wall Connector is on a 60 amp breaker and, so, can deliver 48 amps at 240VAC.
Old Jul 23, 2020 | 07:55 AM
eMINIman's Avatar
eMINIman
Last year when I ordered my MINI Cooper SE (yet to arrive), I read that the car could charge on AC at 11 kW. So I ran out and replaced my 9.6 kW EVSE (used to charge my Honda Clarity PHEV) with an 11 kW (48 Amp) ClipperCreek EVSE. That was a mistake because I later learned that the SE can charge at 11 kW only on a 3-phase EVSE, which is something found only in the UK and Europe. My old 9.6 kW EVSE would have been more than adequate for the 7.4 kW charging rate of the MINI Cooper SE on single-phase AC. In addition to the increased cost of the 48-Amp EVSE, I'm now stuck with a really thick, heavy charging cord that is a bit unwieldy for my wife to wrangle.
MoxieRocket
R58 :: Coupé Talk (2012+)
Feb 15, 2012 05:06 AM
kgdblu
DC Metro MINIs (Archive)
27
May 9, 2007 07:19 PM
Elmann
Jul 17, 2005 07:32 PM
darbmark
Feb 13, 2005 09:34 PM
Kohu'ulaMINI
Hawaii
Jun 4, 2003 12:50 AM
