cold start fuel issue
Old Apr 2, 2020 | 09:23 AM
E34M5's Avatar
E34M5
Hi recently having a cold start missfire and stall, swapped out the high pressure fuel pump, new plugs, coils etc. appears to be fuel related. no issues after car driven for 1 minute. I suspect a leak down of fuel pressure in the low pressure supply side. Does anyone knows if there is a separate valve that prevents back flow or is it built into the transfer pump in the tank. I used to work for w Mercedes Benz and they had an issue with the B class fuel pumps leaking down overnight causing a cold start issue. possibly the same issue here? anyone else had this problem??
Old Apr 2, 2020 | 10:03 AM
MrGrumpy's Avatar
MrGrumpy
Well...... I honestly have no idea. One of the other guys who are more schooled on the fuel side of things will have to weigh in on that. There is a second low pressure pump. That should provide some pressure when the key is on. I think it’s around 60psi, but don’t quote me on that, is been a while since I’ve looked into it. But with everything you’ve replaced, it would seem a logical next thing to look at. Along with the injectors and fuel rail seals. Do you have a scan tool or something that you can use to monitor the fuel pressure on a cold start?
Or you may have gotten a bunk HPFP?
Old Apr 2, 2020 | 12:32 PM
E34M5's Avatar
E34M5
strange no missfires or codes when hot, RPM tune running 20 psi boost, you would think if there was a injector seal or fuel rail seal leaking it would cause an issue under high load/high rpm. might have to swap out the fuel tank transfer pump next
B dub
16
Oct 31, 2019 10:12 PM
HowardH
12
Jan 21, 2019 11:22 AM
bralston9
Jan 28, 2015 06:45 AM
jerrybe
Dec 31, 2014 10:36 PM
Maltep
Jul 20, 2009 10:21 AM
