Found intake hose missing
Old Mar 25, 2020 | 04:20 PM
Paul Hinton's Avatar
Paul Hinton
I found a intake hose missing. It is above the PCV connector on the intake manifold. I can not see where it goes to. Anyone have any idea?
Old Mar 25, 2020 | 04:52 PM
Jason Cornelius's Avatar
Jason Cornelius
Do you have a tube plugged in on the passenger side back of the valve cover?
you can see I have a plug in mine. There should, if stock, be a tube from this corner down into throttle body.
Old Mar 25, 2020 | 05:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Nothing there is some other threads on this but it doesn't have anything that connects to it
Old Mar 25, 2020 | 05:26 PM
Jason Cornelius
that is where I was heading.
Old Mar 25, 2020 | 05:53 PM
Paul Hinton
I will put a cap on it
Thanks. I was feeling around down there and found it disconnected. I did see where the PCV hos is connected. I was verifying that the PCV had no holes in the hose. I might just put a cap on it while I'm down there. BTW Jason, I did fit the noise maker back where it should have been. Thank man!!!
Old Mar 25, 2020 | 06:12 PM
Jason Cornelius
Yep, no problem.
doctahjones
R60/R61 Stock Problems/Issues
Feb 17, 2020 02:12 PM
Greg Eldada
Jul 24, 2019 07:33 PM
jjcsnlynn
Mar 28, 2019 08:21 PM
cargod4490
11
Aug 14, 2012 11:06 AM
