R50/53 I ended up with a spare bolt, help is needed.
Old Mar 19, 2020 | 09:40 AM
Sens's Avatar
Sens
I just bought a 03 r53. It was partially in parts bc an alternator change and supercharger service. I have put it back together and I have a spare bolt left over which I don't know where belongs. It says "ESKA 88" on the head. Its 10cm long and the head is a 13mm. Help is much appreciated! Thanks
Old Mar 23, 2020 | 03:46 PM
Mini Devil's Avatar
Mini Devil
Looks like the long bolt that goes through the SC
Old Mar 23, 2020 | 06:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Looks like the lower A/C compressor bolt. Attaches the compressor to the oil pan.
Old Mar 25, 2020 | 06:07 PM
robj's Avatar
robj
It isn't the bolt that goes up through the frame for the oil filled motor mount is it? [sorry, I'm sure there's a more official name for that motor mount, it just won't come to me this minute.]
That might be easy to miss as it's out of sight when looking at things.
robj
Old Mar 29, 2020 | 11:02 AM
robj's Avatar
robj
Did you ever figure where the extra bolt went?
rob
Old Mar 29, 2020 | 04:07 PM
deepgrey's Avatar
deepgrey
robj
That bolt has a torx head.
Old Mar 29, 2020 | 04:40 PM
robj's Avatar
robj
You're right! I forgot about that. Hope you figure it out.
rob
Old Mar 29, 2020 | 06:29 PM
ptkacik's Avatar
ptkacik
I would guess a supercharger or a/c compressor bolt. I'm not familiar with superchargers as my Mini doesn't have one.
Interesting. An M8 x 100 hex head bolt with captured washer. It is 8.8 grade and has a factory corrosion resistant coating. The residue indicates it goes into a long housing and probably does not experience the outside world (not enough dirt on it). The damaged hex indicates it was hard to remove as if it has a 13mm hex, there isn't a slightly larger SAE wrench size.
DaRKsMCs
Mar 29, 2020 07:03 PM
mini_sd
Jan 22, 2019 07:32 PM
Gizzy
Tires, Wheels, & Brakes
Sep 10, 2006 11:47 AM
SOCRATES
Dec 1, 2005 03:22 PM
Calvin77
Southern California
Nov 10, 2004 07:37 AM
