Interior/Exterior Rear Tail light Diode
I have the factory rear fog light but would also like to have the rear tail light mod for brighter brake lights. I've heard there is a diode that can be used that will allow the factory fogs to work as well as doubling up the tail lights, does anyone know anything about the diode mod?
Brake light mod info courtesy of Greatbear here:
https://www.northamericanmotoring.co...ighlight=diode
scroll down for the non-soldering info. it works with the rear fogs.
Basicly you take a 3 amp diode and stuff the striped end in with the #1 wire on the brake light harness, and the other end in #4. Wrap the exposed area with electrical tape.
yeah greatbears post was the best one. good photo's and directions. i used it to my car and many cars afterwards. it is easy! good luck
Here's a link that is cheap and easy to do. Not sure there is a light in the assembly that is not used.
http://www.myminiparts.com/Products_...keLightKit.htm
3 amp diodes are under $2/pair at Radio Shack:
http://www.radioshack.com/search.asp...1=submit&SRC=1
I'm not suer which one is more appropriate. All MINIs through 04 have the extra bulb from the factory, not sure about the 05s.
Thanks everyone for the help, I picked up a set on the way home tonight and it took a whole 3 minutes to put them in.
Well, here is a pic of the '05 tail light. It is different, and the top bulb is functional - it is the turn signal. Installing the diode makes the white "reverse" light go on, so I yanked it.
cm.d
Aug 19, 2015 08:51 AM
dyeLucky
Aug 7, 2015 07:10 AM
