R50/53 persistant oil leak ...losin it !
Old Mar 14, 2020 | 06:35 AM
frankiev's Avatar
frankiev
A little background
1 Changed oil pan gasket with rtv . Still had an
oil leak ,facing timing chain cover leak on lower left corner of oil pan
2 After recommendation from help here I replaced the gasket again with no rtv and carefully followed tightening sequence ... still leaking same place
3 I drained the oil and cleaned the area well . then i used rtv to seal the outside of the pan/block where the leak was and this morning theres oil there again !!!
How can there be oil with an empty oil pan ? Timing chain cover ??
I looked carefully and its not comming from above .The whole block was cleaned so I could note anything from above ?
side of timing chain cover looks dry .
OMG what the f####
Old Mar 14, 2020 | 06:57 AM
ssoliman's Avatar
ssoliman
Where is the oil? Maybe a pic will help here
Old Mar 14, 2020 | 07:48 AM
Minidogger's Avatar
Minidogger
Maybe it really is coming from above, just following a hidden path.
At the factory I worked at, they would use a blacklight-flashlight to find oil leaks. The oil had UV dye in it.
It might seem extreme to get these things but it made leak point diagnosis very easy.
Old Mar 14, 2020 | 10:40 AM
frankiev's Avatar
frankiev
If you facing the timing chain cover the oil is sitting on the left side where the oil pan meets the block and it's only about an inch or two long area..Great suggestion about the UV thank you . The only thing that still has oil is the filter so I'm changing that and I will try the uv stuff if that doesnt work.
Old Mar 14, 2020 | 01:49 PM
frankiev's Avatar
frankiev
I just checked thouroly and the filter case the oil cooler and the oil filter housing are 100% dry. As crazy as it sounds its comming from the oilpan gasket . I remember when I replaced the gasket the block on that corner didnt look flat but I disregarded it because what th hell would it not be flat . It looked like it was sanded ?
I'm the 3rdcowner so who knows what happened b4 . Any reason anyone can think of for sending the block there?
Old Mar 14, 2020 | 04:16 PM
Minidogger's Avatar
Minidogger
Maybe someone dropped the engine or something stupid like that. You could try to build it up with jb weld or marine tex compound.
Old Mar 14, 2020 | 05:24 PM
frankiev's Avatar
frankiev
I should have checked it with a straight edge. I think I'm going to go ahead and change the timing chain cover gasket .
Island_Moose
Sep 30, 2020 04:05 AM
shanksamillion
Sep 25, 2018 01:25 PM
siggie
Jun 5, 2017 01:00 PM
chav
Mar 15, 2017 10:57 AM
michael8238
Aug 3, 2014 11:23 PM
