09 R56 Mini cooper S CEL & low oil pressure light
Old Mar 8, 2020 | 02:01 PM
yyj3869's Avatar
yyj3869
I just bought 09 mini cooper s with 65K miles and It has check engine light on. I plugged in bluetooth OBD scanner and found out those codes below.
The previous owner told me it heats up sometimes but while I was driving, i didn't notice it's overheating and temp was okay. (I checked coolant temp with obd tool since it doesn't show on dash) he said it would be water pump or thermostat. when i got home and pop the hood after I turned it off, I could hear some kind of water falling noise around bottom of coolant reservoir area which would be thermostat (i guess?)
I believe P0300 - P0304 would be ignition coil and spark plugs but I am wondering what P173B would be.
When I start up the engine, car stalls first time and second try it starts up but idle bumps up to 2k and idle was not stable and low oil pressure light came on. smell from exhaust was like burning oil. What am i supposed to replace? Oil pressure sensor or engine is done?
Old Mar 8, 2020 | 05:32 PM
cpmetz's Avatar
cpmetz
For coolant: thermostat, water pipe and expansion tank.
For oil: put oil in.
For oil consumption: Maybe valve cover, turbo oil feed line, vacuum pump gasket. Maybe valve stem seals.
For codes: timing chain is about to explode.
For bad idle: maybe vanos vanos solenoid, or just the timing being off.
Suggestion: don't drive it anymore.
yyj3869
Mar 9, 2020 05:42 PM
Cristian Dobre
Oct 31, 2019 11:43 AM
mackmini
Nov 24, 2017 10:11 AM
greentrees
Apr 11, 2016 08:42 AM
jc8825
Aug 11, 2015 09:53 AM
